Pentax Lens Review Database » Film Era Pentax K-Mount Lenses » Pentax K-mount Teleconverters and Adapters
Rear Converter-A 1.4x-S Review RSS Feed
4 26,952 Tue December 4, 2018
100% of reviewers $133.33 8.50
Description:
Pentax Super Multi Coated 1.4x teleconverter with KA mount lens information contacts.
Features of this teleconverter:
  • Manual Focus
  • Supports Tv or P exposure mode (in addition to M and Av), if the camera and lens allows
  • The converter does not transmit focal length and MTF information from lens to camera
  • Designed for lenses up to and including 300mm, with some exceptions.
The following lenses are NOT supported:
  • FA* 200mm F4 Macro
  • F* and FA* 300mm F4.5
  • F* and FA* 250-600mm F5.6
  • K 135-600mm F6.7
  • All other lenses above 300mm
  • K and A 15mm F3.5
  • K 18mm F3.5
  • M 24-35mm F3.5 zoom
The above lens compatibility information is from 2006 and predates the introduction of D FA, DA, DA L and DA* lenses. Compatibility with these newer lenses is not readily available.
Rear Converter-A 1.4X-S
Image Format
Full-frame / 35mm film
Lens Mount
Pentax K
Light Loss
1 stop
Magnification
1.4x
Optics
5 elements, 4 groups
Mount Variant (Rear)
KA
Mount Variant (Front)
KA
Focusing
Manual
Coating
SMC
Weather Sealing
Case
HB-90B or S70-70
Diam x Length
64.5 x 21.5 mm (2.54 x 0.85 in.)
Weight
145 g (5.1 oz.)
Production Years
1984 to 2005
Notes
Engraved name: REAR CONVERTER-A 1.4X-S
User reviews
The converter retains all exposure modes supported by the attached lens.
The converter does not relay information about focal length, MTF, or lens name to the camera.
The converter is designed for lenses 300mm and shorter, but it is not compatible with the FA* 200mm F2.8 Macro, the F* and FA* 300mm F4.5 lenses, other lenses and zooms with a reach beyond 300mm, the K and A 15mm F3.5, the K 18mm F3.5, the M 24-35 F3.5 zoom, and various other wide angle lenses due to the protruding rear elements of these lenses.
Variants
Initially the converter was supplied with a hard case, later with a soft case.
Features:
Automatic ApertureFull-Frame SupportDiscontinued
Price History:
Add Review of Rear Converter-A 1.4x-S
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-4 of 4
Lens Review Date: December 4, 2018 I can recommend this lens: Yes | Price: N/A | Rating: 8
Pros:
Cons: somewhat disappointed with the image quality
I had this for about four years but did not use it until I bought a Pentax A* 300mm f4. I am somewhat disappointed with the resulting image quality because it is rather soft. Downsizing from 24 to 12MP with some software sharpening improves the images. Web publishing looks good without any tweaking.
The following were taken with the Pentax A* 300mm f4 + 1.4X-S TC
(100% crop)
(100% crop)
Lens Review Date: January 31, 2017 I can recommend this lens: Yes | Price: $150.00 | Rating: 10
Pros: Sharp, maintains clarity
Cons: somewhat rare
A very useable teleconverter. This 1.4x is quite a bit sharper and more practical for maintaining image quality than rear converter-a 2.0x-s or other 2x converters I tried. Feels like an a series lens because of the grip. No m series 1.4x option. Works well with M* 300 f4, which is where I almost exclusively use this. Images are still acceptable in quality for all photo editors so far.
Loyal Site Supportaxian
Lens Review Date: December 3, 2016 I can recommend this lens: Yes | Price: $110.00 | Rating: 8
Pros: Great performance, Better compatibility with lenses than others.
Cons: None, other than no Data or AF connection.
Unlike its 2x brother, which is a diva that only plays well with certain lenses, this rear converter plays well with most, including many modern lenses.
Sharp and contrasty, small in size. This along with the 1.4x L version are the very best of all the classic Pentax Rear converters, only surpassed by the modern HD DA 1.4 Rear Converter.
I rate this an 8. It's very good, but not outstanding. It is sharper than the 1.7x AFA.
4 users found this helpful
Lens Review Date: January 26, 2012 I can recommend this lens: Yes | Price: $140.00 | Rating: 8
Pros: Genuine Pentax coatings, good glass, works will with my lenses
Cons: It is a teleconverter. it was designed for shorter lenses
This adapter works well with any of my lenses, maintaining all exposure functions. It cannot, of course, turn either of my M lenses into an A series lens.
My use for the adapter these days is with the M400/5.6 which becomes a quite nice M560/8 with the adapter on the back. The IQ is not horribly degraded with the adapter. The quality is better than an equivalent crop with the 400 on my K10D, despite the adapter being designed for use with lenses no longer than 300mm.
It would be better if the lens could be fitted with the -L adapter, but they are not physically compatible because the projection on the -L is bigger than the throat of the M 400.
All times are GMT -7. The time now is 05:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
