Pentax Lens Review Database » Film Era Pentax K-Mount Lenses » Non-SMC Pentax Zoom Lenses
Takumar-F 28-80mm F3.5-4.5 Review RSS Feed
Sharpness
 7.2
Aberrations
 5.8
Bokeh
 6.4
Handling
 6.6
Value
 7.8
Focusing
 4.0
7 41,628 Mon October 8, 2018
57% of reviewers $37.43 6.43
Description:
This autofocus zoom lens has no SMC coating and is identical to the PENTAX-F 28-80mm lens. It has a simpler optical construction with only 8 elements as compared to the SMC coated smc PENTAX-F version.
Image Format
Full-frame / 35mm film
Lens Mount
Pentax K
Aperture Ring
Yes (A setting)
Diaphragm
Automatic, 6 blades
Optics
8 elements, 8 groups
Mount Variant
KAF
Check camera compatibility
Max. Aperture
F3.5-4.5
Min. Aperture
F22-32
Focusing
AF (screwdrive)
Quick-shift
Min. Focus
100 cm
Max. Magnification
0.25x
Filter Size
58 mm
Internal Focus
APS-C: 55-20 ° / 46-17 °
Full frame: 75-30 ° / 65-25 °
Hood
No dedicated hood
Case
No dedicated case
Lens Cap
Dedicated push-on
Coating
Weather Sealing
Other Features
Diam x Length
65.5 x 93 mm
Weight
408 g
Production Years
1988 (start of production)
Engraved Name
TAKUMAR-F ZOOM 1:3.5-4.5 28-80mm
Product Code
Not known
Reviews
User reviews
Notes
No SMC coating
Features:
Screwdrive AutofocusAperture RingAutomatic ApertureFull-Frame SupportDiscontinued
Price History:
Add Review of Takumar-F 28-80mm F3.5-4.5
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-7 of 7
Lens Review Date: October 8, 2018 I can recommend this lens: No | Price: $13.00 | Rating: 4
Pros: price, construction, useful range, nice rendering when it's stopped down a bit
Cons: focus distance, weird macro mode, performance wide open
Sharpness: 7    Aberrations: 3    Bokeh: 5    Handling: 4    Value: 5    Camera Used: K-1    Focusing: 4
This is probably the worst lens I own.
My copy is in nice shape; I got it for peanuts on eBay because I like the Takumar-F 70-210 and 35-70 a lot.
Wide open, it's pretty miserable. Soft everywhere with a lot of glowy spherical aberration in the highlights.
It gets a lot better stopped down a half stop, and a full stop gets rid of the glow and sharpens up the center nicely. The edges never get super sharp, but that's not particularly unusual for late 80s zooms.
The rendering is actually pretty nice. It has the traditionally Pentax-y colors that I tend to prefer to my real go-to lens in this range, the Tamron 28-75. When it's stopped down, it does have some of that Takumar look.
But it's such a pain to use. In addition to the variable aperture, the close focus distance is variable too, and always too far away. The macro mode is awkward and only works at the long end. Not being usable wide-open means that the aperture range is even more punishing than it would have been if it worked well at its printed max. It flares like crazy.
It's possible to wring good work out of this ancient, cheap-o lens. It's not very pleasant, though. It was worth $13 for the novelty value, but I can't recommend actually using it.
1 user found this helpful
Lens Review Date: February 19, 2017 I can recommend this lens: Yes | Price: $30.00 | Rating: 7
Pros: Price. The F series is made of glass and iron.Very fast autofocus. macro mode-good Boke
Cons: not the large aperture
Sharpness: 7    Aberrations: 6    Bokeh: 7    Handling: 8    Value: 8    Camera Used: К-10D,K-7,*istDs
Price. The F series is made of glass and iron.It is generally the "family album", the working horse for a competent beginner, some reports also can do.Great lens for every day.Very fast autofocus in macro mode-good Boke ,not the large aperture,
Lens Review Date: December 8, 2014 I can recommend this lens: Yes | Price: $30.00 | Rating: 7
Pros: Inexpensive, Sharp at F8, Solid Construction
Cons: AF hunts a bit, very soft wide open
Sharpness: 8    Aberrations: 7    Bokeh: 6    Handling: 8    Value: 9
Good inexpensive lens. Picked this up used at a camera show. My LBA was needing to be feed and I figured I couldn't go that wrong for $30. And I have to say, it's a lot better than I expected it to be. It's a very odd lens, very quirky. It's very soft wide open, very sharp at F8 and pretty good at F16. The macro function is okay too, though not it's strong point.
My copy is very clean, and in very good shape. Appears almost new, very little wear and tear on it. Glass is perfect.
I haven't spent a lot of time with this lens, and I don't expect I will ultimately but I am impressed that it is as sharp as it is. Definitely better than the 18-55 kit lens.
Lens Review Date: November 20, 2014 I can recommend this lens: Yes | Price: $40.00 | Rating: 8
Pros:
Cons:
Sharpness: 9    Aberrations: 8    Bokeh: 8    Handling: 7    Value: 10    Camera Used: k-x
I bougt takuma F 28-80 non smc but i abrupt it take to me. it's verry Sharpness but too heavy
Lens Review Date: November 1, 2013 I can recommend this lens: No | Price: $10.00 | Rating: 6
Pros: cheap and light
Cons: optical performance, construciotn
Sharpness: 5    Aberrations: 5    Bokeh: 6    Handling: 6    Value: 7
cheap bad quality and low performance...
Lens Review Date: December 6, 2010 I can recommend this lens: No | Price: $50.00 | Rating: 6
Pros: Cheap, well-built, sharp wide open
Cons: AF hunts a lot, minimal distance makes macro useless, colors in artificial light is eh, coating will not compensate for digital sensors
Iíve had the opportunity to use the Takumar-F as an alternative to my fast zooms since I figured the extra reach would help, as my other two zooms donít go any longer than 60mm. The f-stop difference is not that significant for me and you can get these for a song. Itís macro too, but the macro feature is strange: you twist the zoom ring past the 80mm mark and it will focus in a specific range for macro that is too far in minimal distance to offer you a really good image.
Now, the one thing I should add is that I donít use this lens for the outdoors. Itís not because I canít, but because I donít normally do outdoor photography and when I do, Iím usually using a faster lens or something with more reach. I am mentioning this because I am unsure about the quality of the coatings here. I can say that from my overall experiences that the colors seem to come off as flat under artificial lighting. Iím sure that stopped down the colors would have a more appealing appearance. That said, I also donít use the lens for colors either.
So why do I bother using it? The truth is that I use it because itís sharp when shot wide and undercoated compared to most modern lenses. Since I use it for infrared photography, I need something that can focus well. Now, granted, the autofocus isnít very remarkable in low-light (Iíve had it miss its mark on a K20 several times because there was not enough available light coming in). It also does not bring much light to the viewfinder and the focus ring is small, but when you find your mark with the lens, it can really shine.
I might stop using this lens if I ever acquire an older manual zoom, but for now it does its job. No, I would not recommend people to use this unless they are looking for a challenge, but if they need something on the cheap for B&W shots, I would probably push this lens their way.
Lens Review Date: November 27, 2009 I can recommend this lens: Yes | Price: $89.00 | Rating: 7
Pros: 28-80 mm focal length covers a lot of ground
Cons: Vignetting, though that may just be me
This lens came bundled with a Pentax SF10, that included a normal Pentax lens (50mm 1.7), for a total of $389.00, in 1990, at Kearny Discount Camera in San Francisco. I estimate the lens was about $89 of the $389 price. I have used the camera and lenses for 19 years in a variety of situations, and can't say anything bad about this lens.
I am experiencing a fair amount of vignetting, that I can more-or-less remove in Photoshop CS4, but I would prefer to eliminate it at shooting time. I would appreciate any thoughts on the subject that others may have. I do have a 58 mm UV filter on the lens, and do not use a lens hood.
All times are GMT -7. The time now is 11:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
