Pentax Lens Review Database » Pentax 67 Medium Format Lenses » 67 Wide-Angle Primes
SMC Pentax 67 / SMC Pentax-6x7 45mm F4 Review RSS Feed
Sharpness
 8.9
Aberrations
 8.2
Bokeh
 7.3
Handling
 10.0
Value
 9.5
18 87,077 Mon March 9, 2020
100% of reviewers $353.33 9.35
Description:
Ultra wide angle lens for the Pentax 6x7 format with 76 degrees field of view horizontally, roughly like a 24mm lens on a 24x36mm camera.
Two versions were offered with the same optical formula, the photo above shows the second version.
© www.pentaxforums.com, sharable with attribution | Check camera compatibility
Image Format
6x7
Lens Mount
Pentax 6x7
Aperture Ring
Yes (no A setting)
Diaphragm
Automatic, 8 blades
Optics
9 elements, 8 groups
Mount Variant
Inner Bayonet
Max. Aperture
F4
Min. Aperture
F22
Focusing
Manual
Min. Focus
37 cm
Max. Magnification
0.17x
Filter Size
82 mm
Internal Focus
89 ° / 76 °
Hood
Case
Lens Cap
Coating
SMC
Weather Sealing
Other Features
Filter Bayonet
Diam x Length
91.5 x 57.5 mm
Weight
486 g
Production Years
1980 to 1989
Notes
Engraved name: smc PENTAX-6x7 1:4 45mm
User reviews
Variants
1980: smc PENTAX-6x7 1:4 45mm (this lens)
1989: smc PENTAX 67 1:4 45mm
SMC Pentax 67 45mm F4
Image Format
6x7
Lens Mount
Pentax 6x7
Aperture Ring
Yes (no A setting)
Diaphragm
Automatic, 8 blades
Optics
Mount Variant
Inner Bayonet
Max. Aperture
F4
Min. Aperture
F22
Focusing
Manual
Min. Focus
37 cm
Max. Magnification
0.17x
Filter Size
82 mm
Internal Focus
89 ° / 76 °
Hood
Case
Lens Cap
Coating
SMC
Weather Sealing
Other Features
Filter Bayonet
Diam x Length
91.5 x 57.5 mm
Weight
486 g
Production Years
1989 (start of production)
Notes
Engraved name: smc PENTAX 67 1:4 45mm
User reviews
Optics unchanged from previous model
Holder for gelatin filters on the rear
Variants
1989: smc PENTAX 67 1:4 45mm (this lens)
Features:
Manual FocusAperture RingMedium-Format SupportAdapter needed for DSLRsDiscontinued
Price History:
Add Review of SMC Pentax 67 / SMC Pentax-6x7 45mm F4
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-15 of 18
Lens Review Date: March 9, 2020 I can recommend this lens: Yes | Price: $450.00 | Rating: 9
Pros: Useful WA field of view, good sharpness and contrast
Cons: CA in the corners sometimes.
Sharpness: 9    Aberrations: 6    Bokeh: 5    Handling: 10    Value: 9    Camera Used: Pentax 67II
This is my widest lens for the Pentax 67II. While it produces great images in its own right, its performance pales when you compare it to the 55 mm f/4 and 75 mm f/2.8 lenses. It is an older design that was never revised and it shows. 67 lenses should be used around f/11 and f/16 for best performance in landscape pictures. All in all, a very honest performer.
Today I mounted the 45 mm f/4 on my 645Z digital body. The results are beyond belief. What behaved like a so-so, almost mediocre, lens on the 67 II reveals itself to be a SWEET lens on the 645Z with beautiful colors, very uniform sharpness starting @ f/8 and the usual "deep contrast" of 67 lenses. The 45 mm is very compact, quite light and easy to focus with its f/4 aperture. Best apertures are between f/8 and f/16. These 67 optics are the "Major Leagues" of medium-format lenses.
Lens Review Date: December 31, 2019 I can recommend this lens: Yes | Price: $140.00 | Rating: 10
Pros: Compact, light, strong performer.
Cons:
Sharpness: 8    Aberrations: 8    Bokeh: 8    Handling: 10    Value: 10    Camera Used: 6x7 MLU
Widest rectilinear lens for the 67 system. I happen to have the bayonet smc skylight filter for it. It's pretty much a pancake lens for the 6x7. Small and light. It's almost perfect, if only it had seven aperture blades instead of eight like the smc DA15/4, which performs quite similarly, since one has to focus for the corners and stop down accordingly for depth of field of the rest due to its field curvature.
Lens Review Date: September 28, 2019 I can recommend this lens: Yes | Price: $280.00 | Rating: 9
Pros: Only game in town for what I need
Cons: Chromatic aberation
Sharpness: 8    Aberrations: 8    Bokeh: 5    Handling: 10    Value: 10    Camera Used: Fuji GFX 50R
I needed a 45mm lens with a generous image circle that allowed for shifts and tilts on a 33mm x 44mm sensor (Fuji GFX 50R). I'm using the GFX 50R as a "medium format back" on my Toyo VX23D (a "technical camera" -- basically a scaled-down view camera with full movements on front and rear standard). The P67 45mm lens was the only good option I could find. The image circle on the P645 45mm lens is a bit tight (and that lens has performance issues); also, lenses that work well on technical cameras with flangeless medium format back don't fit on my setup because the GFX has such a longe flange distance (26.7mm). Mounting the P67 45mm lens on my Toyo camera was a bit of a challenge, but my solution works very well. I pulled the screws in the Pentax mount, and then used longer M1.7x8 screws to screw the lens directly to a flat lens board. Of course, you can also keep it simple and use it on a Fuji GFX camera with a tilt-shift adapter.
I'm really pleased with how this worked out. I also use the Pentax-A 645 35mm f/3.5 on this camera. As others have noted, the P645 35/3.5 A is an excellent lens. It's definitely resolves a bit more than the P67 45mm, but that doesn't mean the P67 45mm is "soft". For my purposes, it's plenty sharp. More importantly, as a shift lens it's very good. I notice extremely little distortion when making shifts, even large ones; in contrast the P645 35mm has complex distortion that becomes obvious as you shift more, and is hard to fix. The P67 also allows for much more shift. I can get 10mm of good quality shift on my sensor with the P645 35mm lens, but the P67 45mm allows for up to 25mm (with noticeable illumination falloff at the edges, some correctable colour shifts, and purple fringing); very good 20mm shifts are possible, and 15mm shifts are usually excellent. That more than meets my needs.
The Achilles's Heal of the P67 45mm is chromatic aberration, specifically strong purple fringing on large shifts. At 0mm (unshifted), there's none that I can see. At 15mm, a small amount is noticeable under some conditions. At 20mm, it can be quite strong, and at 25mm it's very strong. For context, a 25mm shift is double what a typical shift-adapter allows. If you're using a shift adapter that only allow 12mm of shift, you may never see the problem. Most of the time I'm able to clean up the CA in Lightroom with little damage to the image.
As a bonus, the lens is quite small and light for a P67 lens, and very pleasant to use. My copy came with the clip-on lens hood. Although a bit flimsy, this design is perfect for my situation because it allows me to easily position the hood to align with the long edge of the sensor; on my camera the lens stays still and the camera is switched between portrait and landscape orientations, so the lens hood has to be able to switch orientations too.
All in all, if you need a 45mm retrofocus shift lens on a 33mm x 44mm sensor, this is an excellent choice. Highly recommended.
Lens Review Date: February 16, 2019 I can recommend this lens: Yes | Price: $275.00 | Rating: 9
Pros: Compact (as far as Pentax 67 lenses go), no visible distortion
Cons: Relatively high CA, especially in the corners, noticeable field curvature, not as sharp as other 67 lenses, such as the latest version of 55mm F4
Sharpness: 7    Aberrations: 7    Bokeh: 5    Handling: 10    Value: 9    Camera Used: Pentax 6X7
I've been using many samples of this lens on just as many samples of Pentax 67 bodies ever since it was originally introduced. Currently I own the latest version of it. I've used it professionally for product, interior, landscape, street, and wedding photography with great success. The lens handles superbly, it is compact and relatively light, in fact, it may be the third smallest and lightest lens in the Pentax 67 line-up, behind the 75mm F2.8 AL and 90mm F2.8. The lens has very little, if any geometric distortion, when used correctly. It also looks great on Pentax 67 body. It does have 82mm filter size, but I standardize my 67 system to 77mm filters, so I always use a slim 82-77 step-down ring on this lens, which it allows without any vignetting.
But optically the lens is lacking. Specifically, there is pronounced field curvature, forcing the user to balance-focus the center with the corners using high-powered magnifier directly on the ground glass screen and then stop down far enough to let the depth of field sharpen everything up. Normally F11 or F16 works for me, squeezing out the maximum amount of sharpness the lens can deliver.
Furthermore, there is significant amount of CA, especially in the corners, depending on your subject matter.
Finally, the lens is not sharp enough for me, regardless of the focusing method used, definitely lagging behind the latest version of the 55mm F4. Probably the only 67 system lens that is less sharp than this one is the 35mm Fish-Eye. I am not even going to mention the bokeh, because it is insane to expect any kind of bokeh quality from an ultra-wide angle lens, such as this one.
But since there is no other choice, I've learned to live with the lens in a love-hate relationship over the years, working around its weaknesses and enjoying its strengths. In spite of my whining, this little lens had on many occasions delivered superb images for me and what can I say - I just love to hate it!
Lens Review Date: March 17, 2017 I can recommend this lens: Yes | Price: $200.00 | Rating: 9
Pros: Very sharp, excellent contrast, very little if any distortion
Cons: none that I can think of.
Sharpness: 9    Aberrations: 9    Bokeh: 8    Handling: 10    Value: 9    Camera Used: Pentax 67
I'm still fairly new to the Pentax 67, having bought my camera a little less than two years ago and with the 45mm, even less than that. So far, I've shot only Tri-X 400 with it. I do my own developing and I develop my negatives in Kodak D-76. This provides me with good, medium grain exposures that result in solid looking final images.
About the lens, of the few lenses in my Pentax 67 outfit, this 45mm is, by far, my favorite. I consider this angle -- being the equivalent to a 24mm in 35mm format -- to be just about the perfect angle for general wide-angle photography. And this 45mm does not let one down. It is sharp, edge to edge, and I can't detect any appreciable level of distortion. Contrast is excellent. Depth of field is great. I would prefer to let my images do the talking though, so here goes.
The Northrup F5 Tiger II flew an "aggressor" role with the Air Force's Red Flag advanced pilot training school (the AF equivalent to the Navy's Top Gun school). Note the star on the tail. It's red, exemplifying the red star worn by the former Soviet Union military aircraft. Exposures were 1/1000 @ f/11.
A shot from my front yard facing out our cul-de-sac. Exposure was 1/500 @ f/8.
All images were scanned on an Epson 4990 scanner @ 2400 ppi using Epson Scan software.
Lens Review Date: January 18, 2017 I can recommend this lens: Yes | Price: $225.00 | Rating: 9
Pros: Sharpness, colour, lack of distortion, size, light falloff
Cons: CA in extreme corners
Sharpness: 10    Aberrations: 8    Bokeh: 8    Handling: 10    Value: 10    Camera Used: Pentax 67II
No lens is a 10... I would rate this lens a 9.5. It is superb. I also have the 75mm 4.5 and 105 2.4 (both SMC), and subjectively this is my favorite.
The lens delivers a crisp rendition of detail and a 3D look to the images. In my opinion, the angle of view is not too wide. At 45mm, the appearance of the scene (perspective) is actually very natural.
Bokeh can be just slightly harsh when there is a busy background and the focus is on a near object, but that's typical for a lens of this type. Focuses very close, which is great. Colour is beautiful, and it handles incident light very well.
I have a high-resolution scan of an image of some trees taken in nearly ideal conditions (1/125 shutter, F8), and you can make out individual pine needles about 80 feet away. That's on Portra 400. I'm certain that the lens is out-resolving the scanner. Can't wait to try out some Ektar or Portra 160 in the summer months.
Lens Review Date: May 10, 2015 I can recommend this lens: Yes | Price: $240.00 | Rating: 10
Pros: no flare size weight sharp contrast and where the distortion?
Cons: Purple chromatic aberration on the corner/Bokeh with slight white outline
Sharpness: 10    Aberrations: 8    Bokeh: 8    Handling: 10    Value: 9
note my is earlier version come with genuine lens hood . (slightly tighter focusing ring but not affect on image quality)
It's sharp and contrasty I almost couldn't find any distortion except when you use a ruler to see.
it's has Super-Angulon lens design (similar to Schneider/Leica 21mm lens).
but there some drawback there some ca in the corner when you inspect closely and not so nice bokeh.
Lens Review Date: January 21, 2015 I can recommend this lens: Yes | Price: $250.00 | Rating: 10
Pros: size, weight, fast focus, small
Cons: None
Sharpness: 10    Aberrations: 9    Bokeh: 8    Handling: 10    Value: 10
I really love this lens for traveling photography. The focus ring is really smooth that you can quickly focus on any subjects. I'm impressed about the size and weight too. Someone mentioned the filter size as one of cons. WTF. This is the widest(except fish eye lens) lens. Why do you argue about the filter size since the lens is the wide lens? I love the sharpness while I used color and B&W films.
2 users found this helpful
Lens Review Date: March 7, 2014 I can recommend this lens: Yes | Price: $450.00 | Rating: 9
Pros: Sharp and wide.
Cons: 82mm filter thread. Missing a f/32 aperture.
Camera Used: 6x7, 67 and 67II
The 45mm lens is a relative newcomer to the Pentax 6x7 system and the first version (6x7 45/4) was released in 1980. I have the second and last 1989 version (67 45/4) and it has the same optics as its predecessor.
Usage:
The 45/4 is a nice wide lens with a very good minimum focusing distance. This is the widest non fish-eye lens you can get for the Pentax 6x7 system. The 45/4 is sharp, but not in the same league as the 67 55/4, especially in close-up detail. A little more DOF would help, so a f/32 minimum aperture is needed. The 45/4 is also light weight for a Pentax 6x7 system lens, so no issues hand holding it.
FILTER: The 67 45/4 uses 82mm screw in filters, or Pentax 6x7 82mm bayonet filters. The lens also accepts rear mount gelatin filters. Unfortunately 82mm filters are expensive, even the old Pentax bayonet ones. It would have been nice if this lens also got updated and accepted 77mm filters, like the 67 55/4.
CASE: The 67 45/4 comes with the S90-100 soft case.
HOOD: The 67 45/4 uses a plastic clip-on PH-SB82 hood.
Summary:
The 67 45/4 is a great little lens, though not as good as the 67 55/4. Just wish it didn’t use those 82mm filters!
Price: I found my 67 45/4 here on the Pentax Forum and it cost $450.00. It was EX+ condition and came with the original box and case. I purchased the hood separately.
Sample shots taken with the 67 45/4. Photos are medium resolution Lab scans from original negatives and slides.
Camera: 67 Film: Kodak Tri-X 400 ISO: 400
Camera: 67 Film: Kodak T-Max 400 ISO: 400
Camera: 67II Film: Fuji Provia 400X ISO: 400
1 user found this helpful
Lens Review Date: February 6, 2013 I can recommend this lens: Yes | Price: N/A | Rating: N/A
Pros: Small, lack of distortion, sharp
Cons: nothing
Sharpness: 9    Aberrations: 9    Bokeh: 9    Handling: 10    Value: 10    Camera Used: Pentax 67
I bought this lens together with my 67. Compared to the camera it has a very low weight! Because the camera is already heavy itself, a light lens is a big benefit.
I mainly use it for landscapes, it's very sharp, also on f4.0! It had great colors and a great pro is the lack of distortion. In the pictures I made with this lens, there's almost no visible distortion!
Working with this lens is very nice, together with the waistlevelfinder, you'll have a "light" and great set-up for landscape photography.
Here are some examples: http://www.flickr.com/photos/svanvenetien/sets/72157632555467593/with/8417370862/
Winter Beach by Sebastiaan van Venetiën, on Flickr
White Beach by Sebastiaan van Venetiën, on Flickr
Lens Review Date: September 6, 2012 I can recommend this lens: Yes | Price: $385.00 | Rating: 10
Pros: Small size, 0.5 stop between f16 and f22
Cons: Irksome MAN/AUTO lever
Sharpness: 9    Aberrations: 9    Bokeh: 8    Handling: 10    Value: 10    Camera Used: Pentax 67
A squat little companion to the bigger brother 55 f4 with an optical span to match, though 55 still holds the edge — but not by much to my eyes!
For people with small hands this lens is a treat to use, with all controls falling comfortably and naturally to scale. The focus ring is especially smooth as opposed to the chunkier but no less comfortable 55. In use the aperture ring is a bit stiff and requires a decisive tug, but redeems itself with a useful 0.5 stop between f16 and f22. Like all ultra-wide angle lenses, this lens favours hyperfocal technique to balance depth of field with through-ranged sharpness and as such gets away with the limit of f22 admirably well.
Sharpness on RVP 50 and 100F trannies is outstanding from around f5.6 but I favour f8 on, and this appears to be where it squares up with the 55mm. I cannot see any distortion to squabble about. The front element is clothed by a protective glass which is thoughtful given how easily prominent front elements can be damaged by filters or accident. Art/exhibition printing is exceptionally satisfying to view, so far is the same with the 55mm and 165mm LS lenses -- up to 28x36cm; no real limit except in terms of economics and diminishing wall-hanging space!
In summary an excitingly sharp and contrasty lens which very comfortable and efficient in active handling and possessing an "out there" view with no great weight penalty.
Giveaway winner!
Lens Review Date: December 7, 2011 I can recommend this lens: Yes | Price: $300.00 | Rating: 9
Pros: size, weight, sharpness
Cons: filter size, no f32, dim focus tricky
I like this lens a lot from only the first roll processed. My copy of the lens is indeed in good shape... mostly. I have a question about the sharpness in only a little area of about the last third of the field and it may be user error. The issue is at full open-f4 to f5.6 in medium shadow conditions on 100 iso film from a distance of around 18 feet. Now at f8 there is not a question of excellent sharpness. So, only the wider was a little concern as I've noticed the outer third was ever so slightly less impressive. I didn't recall any mention from others that the slight curvature or distortion would cause this, so I might have to do a careful inspect of the lens for a loose element... as quite a few of my lenses seem to suffer this... but truth be told, tiny knit-pick here since the bulk of the images are superb.
Overall, this lens performed very well indoors and outdoors. Flare control, I agree, very well behaved. The sharpness is mostly outstanding with so much right in front that you will have almost not complaints. This is at times these days a pricey lens for the budget shooters and the two version 55mm f4 might be a better choice as they are nice and wide much as a 28mm in 135 format, but the little extra wide was handy for the group shots although some indoor lighting conditions made it a slow lens to dial in.
Update: No physical issues found. I'll go with sticking to 5.6 and greater.
Lens Review Date: May 25, 2011 I can recommend this lens: Yes | Price: $380.00 | Rating: 10
Pros: Extremely sharp, Excellent colour rendering, Virtually zero distortion
Cons: None
I purchased this lens last year for my landscape stuff and found this lens extremely sharp and with excellent colour rendering. Another thing is that I could hardly find any visible distortion.
Some people moving from Digital / 135 would claim the slow of this lens. F/4, a bit too slow for photography at dim light environment. However I actually stop it down to F/22 and put the camera on tripod to get the longest exposure. This F/4 is nothing to me. Plus that even though I stop it down to F/22, I still get very sharp images. It seems that sharpness has no change all the way from F/4 to F/22.
The non-visible distortion helps a lot in landscape and cityscape photography, so that I don't need to care about the distorted building. Using this lens is a breeze.
So hereby I strongly recommend any Pentax 67 users to buy this lens. You won't regret.
Lens Review Date: March 18, 2011 I can recommend this lens: Yes | Price: $450.00 | Rating: 10
Pros: Extremely sharp. Solid constuction.
Cons:
This is my favorite Pentax 67 lens. I agree with assertions made by others, but this is such an agreeable lens. Images have superb color fidelity, contrast, resolution. Flare can be a problem, but blocking side light with a magazine works very well. A polarizer also blocks side light.
It's not perfect, but from the images you can tell it's a very high quality lens. I think the other reviewer is right about special materials, and perhaps, aspherical elements.
Sometimes variation in style is mistaken for variation in lens quality. In particular, artists who don't use a tripod need to shoot at larger apertures, and there may still be subtle problems of camera shake, if they like coffee as much as I do.
I remember just getting into medium format, hoping the image quality would be what I envisioned. This Pentax WA lenses are even better than I imagined, especially the 45mm and 55mm lenses.
5 users found this helpful
Lens Review Date: March 6, 2009 I can recommend this lens: Yes | Price: $475.00 | Rating: 9
Pros: Small, sharp
Cons: Some variability in perfomance from lens to lens
There are two versions of the 45mm, both are optically the same. The pre-1990 version has rougher aperture ring grip and slightly different rubber focusing ring. I have owned one since 1990 and is probably my most used lens. Needless to say, it is great for landscapes and seascapes. I always take this lens for travel work as it is small and has the angle of view for travel landscapes. This 9 element cross section is very similar to the 21mm Super Angulon-R used for the Leicaflex cameras. Its thick central elements show that the design has Biogon heritage, although modified to clear the mirror box. It uses a floating element for better close up spherical aberration correction. An obvious atttempt to correct the traditional barrel distortion seen in wide SLR lenses, was made. Its slight mustache distortion is not a show stopper. One can have the ocean in the shot without worry of it being noticably curved. I have found that the 45 is better corrected for distortion than Pentax's wide lenses for its 35mm cameras. This lens has an 8 blade diaphragm. The rear of the lens has a gel filter clip, should one want to use one. I use mine stopped down to at least f/8 and mostly to f/22. I have shot it at f/4 a few times with good results. This lens is well corrected optically and is pretty sharp in the corners at f/5.6. This lens is easily sharp enough for publication purposes. My estimate for lp/mm is 85. When comparing chromes from this lens with the 55-100 zoom, they look very similar until you look way off axis, then you can see just how sharp the zoom really is. That's why the zoom is a 10 rating and the 45 is a 9. There are reports of variation in performance from copy to copy, so my estimate above is from what I have seen. Once again, the DOF scale is a bit optimistic, so one has to be a little conservative when setting up shots with DOF. I suggest at least a half stop different on the scale. I have only seen lateral color with this lens in a few shots with extreme contrast . This equates to 4 shots out of 2000 over 20 years. Be careful when using a polarizer with this one, since it is wide enough to cause differential light/dark areas across the sky.
I would have preferrred that the 45 be upgraded like the 55mm to a Distagon-like design but the 45 was probably left alone because it performed so well as is. If I have a choice between using the 45mm or my 55-100 zoom, I usually choose the zoom.
Overall a great lens.
All times are GMT -7. The time now is 02:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
