Pentax Lens Review Database » Pentax 67 Medium Format Lenses » 67 Wide-Angle Primes
SMC Pentax-6x7 55mm F4 Review RSS Feed
Sharpness
 9.5
Aberrations
 9.5
Bokeh
 9.0
Handling
 9.5
Value
 10.0
5 39,852 Sat March 12, 2022
100% of reviewers $256.25 9.00
Description:
This wide angle lens for the Pentax 6x7 system lens has a field of view like a 28mm lens in the 24x36mm film format. The optical design was changed over the earlier Takumar versions which also were heavier since they were a half stop faster at f/3.5.
© www.pentaxforums.com, sharable with attribution | Check camera compatibility
Image Format
6x7
Lens Mount
Pentax 6x7
Aperture Ring
Yes (no A setting)
Diaphragm
Automatic, 8 blades
Optics
9 elements, 8 groups
Mount Variant
Inner Bayonet
Max. Aperture
F4
Min. Aperture
F22
Focusing
Manual
Min. Focus
40 cm
Max. Magnification
0.2x
Filter Size
77 mm
Internal Focus
78 ° / 65 °
Hood
Case
Lens Cap
Coating
SMC
Weather Sealing
Other Features
Filter Bayonet
Diam x Length
91.5 x 75.5 mm
Weight
615 g
Production Years
1979 to 1986
Notes
Engraved name: smc PENTAX-6x7 1:4 55mm
User reviews
Features:
Manual FocusAperture RingMedium-Format SupportAdapter needed for DSLRsDiscontinued
Price History:
Add Review of SMC Pentax-6x7 55mm F4
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-5 of 5
Review Date: March 12, 2022 Recommended | Price: $229.99 | Rating: 10
Pros: Insanely sharp, beautifully built, pleasure to use
Cons: easy to accidentally hit the manual/auto aperture button and flip back to f4
Sharpness: 10    Aberrations: 10    Bokeh: 10    Handling: 10    Value: 10    Camera Used: Canon 6D Mark ii, with tilt/shift adapter
I don't give all 10's lightly. This is a fantastic lens. I literally wrote a poem about my love for this lens in my college poetry class. I would go out on a limb and say that from my experience, and it seems the experience of everyone else who's used and reveiwed this lens, this is one of the very sharpest, cleanest manual camera lenses that was ever made. Edge to edge sharp even wide open, and when you stop down to 5.6 or 8, fuggedaboutit. The bokeh is incredibly smooth; I think not much gets said about this len's bokeh because its not super fast and the bokeh doesn't have much character, but if you spend the time to find the right bokehlicious conditions, this has some of the very most smooth, mellow, undistracting and consistent bokeh I've ever seen. just lovely. Its mostly so clinically sharp that there isn't a ton of unique character, but if you spend time with it, you'll begin to notice that there's a bit of a 70's magazine style tint in the way it renders greens, blues and ambers. Certainly nothing to be upset over, each lens has thier own unique aspects which is what makes them fun. I spet $230 on ebay for my copy which is basically in mint condition. I have a Canon 6D Mark ii that I used the lens with, and I attached it with a Fotodiox tilt / shift adapter, and couldn't be happier. Here's my proof:
Review Date: December 22, 2016 Recommended | Price: $300.00 | Rating: 9
Pros: Great sharpness, handling
Cons: Can't think of any
This is my sole 55mm lens for my P67s; many say the newer 55mm f/4 67 lens is better, but if it is, it can only be slightly so. This lens is no dog by any stretch and its plenty sharp as far as I can tell. Not overly heavy and smooth focusing. I am completely satisfied with this one and have no incentive to get the newer version based on the performance of the 6x7 f/4.
Giveaway winner!
2 users found this helpful
Review Date: November 21, 2010 Recommended | Price: $245.00 | Rating: 9
Pros: very sharp, performed well in tricky lighting
Cons:
Sharpness: 9    Aberrations: 9    Bokeh: 8    Handling: 9    Value: 10
I'm sure the latest version '67' is even more sharper, but that would be about... what... around 11 to 14 lpmm more out of 87-91 lpmm or a max of only 16"x 20" instead of 20"x24"? You can't go too wrong with this version and I might someday borrow a 67 to do a head to head test, but I'm happy enough with this version. Other shots I've made with this lens all had good sharpness, edge performance always very good and flare control was always excellent good when a hood was added. So if you are needing a steady performer on the wide side of things... this is a great one to start with or stay with.
Personal cheer for this lens...
I made a full color cover shot with it in my church's special holiday edition bulletin.
The image was very sharp and clear. People thinking digital had thought it was some pro digital camera with lots of megapix and was well cooked in photoshop or something... nope! I've explained that it was straight film and scanned straight with best resolution. The original shot had all the color contrast and the edge sharpness right there and no need to cook it in anything.
Review Date: February 20, 2009 Recommended | Price: $250.00 | Rating: 8
Pros: Excellent lens
Cons: None noted
The version II 55mm is to me a great lens. I know there is a following around the version III lens, but this one has suited me just fine.
Review Date: June 24, 2007 Recommended | Rating: 9
Pros: Sharpness
Cons: not considered quite as good as the newer 8 element version
It is very easy to confuse this lens with a slightly different 8 element version. Both are very good lenses, but the later 8 element version is considered an absolute classic among some 67 users. Both are f/4 lenses and take a 77mm filter. There is an older f/3.5 version that takes a 100mm filter and is not considered to be in the same class as the two later versions. If I had to choose just one lens for the 67, I'd be satisified with either of the f/4 versions.
All times are GMT -7. The time now is 02:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
