Pentax Lens Review Database » Film Era Pentax K-Mount Lenses » A Zoom Lenses
SMC Pentax-A 35-135mm F3.5-4.5 Review RSS Feed
Sharpness
 8.0
Aberrations
 8.0
Bokeh
 8.0
Handling
 8.0
2 24,644 Sun January 22, 2017
100% of reviewers $150.00 7.50
Description:
This is a manual-focus lens covering a large zoom range from wide-angle to short tele. It has a macro setting at 135mm.
Image Format
Full-frame / 35mm film
Lens Mount
Pentax K
Aperture Ring
Yes (A setting)
Diaphragm
Automatic, 6 blades
Optics
16 elements, 12 groups
Mount Variant
KA
Check camera compatibility
Max. Aperture
F3.5-4.5
Min. Aperture
F32-45
Focusing
Manual
Min. Focus
160 cm
Max. Magnification
0.25x
Filter Size
58 mm
Internal Focus
APS-C: 45-12 ° / 38-10 °
Full frame: 63-18 ° / 54-15 °
Hood
RH-A 60mm
Case
Unknown
Lens Cap
Plastic clip-on
Coating
SMC
Weather Sealing
Other Features
One-touch Zoom
Diam x Length
63 x 92 mm
Weight
450 g
Production Years
1986 to 1989
Engraved Name
smc PENTAX-A ZOOM 1:3.5~4.5 35~135mm
Product Code
27167
Reviews
User reviews
Notes
Case: The later soft case S80-160 fits.
Macro: The lens has a macro setting at the 135mm focal length, where it focuses down to 75 cm.
Features:
Manual FocusAperture RingAutomatic ApertureFull-Frame SupportDiscontinued
Price History:
Add Review of SMC Pentax-A 35-135mm F3.5-4.5
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-2 of 2
1 user found this helpful
Lens Review Date: January 22, 2017 I can recommend this lens: Yes | Price: $150.00 | Rating: 8
Pros: Solid Construction
Cons:
Sharpness: 8    Aberrations: 8    Bokeh: 8    Handling: 8    Camera Used: KS02
I have all a few A series manual zooms, incl the rare 35 -210 (of which i think this of the same build family) and I also have the famous 35-105. Anyway this lens is actually fantastic. it is very sharp at F5.6, and has the pentax pop. Build quality is top notch. AF indicator works fine for manual focus. It is not as good as the 35-105 (manual A series), but a beautiful piece of glass.
Lens Review Date: September 9, 2007 I can recommend this lens: Yes | Price: N/A | Rating: 7
Pros: Nice range, sharp from f5.6, usable in program modes, light and compact.
Cons: zoom creep, softer wide open, light CA
You don't see this one that often. I got a hold of it together with a camera.
Pretty interesting lens.
Wide open it's a little soft, but it from f5.6 on it becomes sharper. At f8 it's actually very nice and sharp. It has some light CA wide open.
This lens is light and compact for its range. Definitely an alternative if you don't want to get noticed too much, and still want some tele-reach.
At f3.5 at 135mm you get kind of a dreamy effect, which could be used for portraits. This effect decreases when you stop down to f4.
I would say this lens is definitely usable for street and portrait photography, and is a good alternative for more expensive zooms in the range.
Like almost all push-pull zooms, my copy has some zoom creep (the focus/zoom ring moving when you face the lens up or down and let go of it) but this presents no problems when using it, as you must have your hand on the lens barrel for focusing anyway.
Tom
All times are GMT -7. The time now is 09:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
