Pentax Lens Review Database » Film Era Pentax K-Mount Lenses » FA Prime Lenses
SMC Pentax-FA 28mm F2.8 Soft Review RSS Feed
Sharpness
 9.0
Aberrations
 8.0
Bokeh
 9.0
Autofocus
 8.0
Handling
 8.0
Value
 9.0
1 35,496 Fri February 17, 2012
100% of reviewers N/A 9.00
Description:
This is a soft-focus lens where the image softness is controlled by the aperture ring (the larger the aperure, the softer the image). The aperture works manually from F2.8 to F5.6 ("stop down" mode), and automatically from F5.6 - F22 (will meter at F5.6 in that range). This lens does not have the "A" setting on its aperture ring.
Image Format
Full-frame / 35mm film
Lens Mount
Pentax K
Aperture Ring
Yes (no A setting)
Diaphragm
Automatic/Manual, 6 blades
Optics
5 elements, 5 groups
Mount Variant
KAF
Check camera compatibility
Max. Aperture
F2.8
Min. Aperture
F22
Focusing
AF (screwdrive)
Quick-shift
Min. Focus
30 cm
Max. Magnification
0.13x
Filter Size
49 mm
Internal Focus
APS-C: 55 ° / 46 °
Full frame: 75 ° / 65 °
Hood
PH-SB49
Case
S70-70
Lens Cap
Coating
SMC
Weather Sealing
Other Features
Soft Focus
Diam x Length
65.6 x 40.3 mm (2.6 x 1.6 in.)
Weight
195 g (6.9 oz.)
Production Years
1997 to 2004
Engraved Name
smc PENTAX-FA 1:2.8 28mm -SOFT-
Product Code
22530
Reviews
User reviews
Notes
Soft Focus adjustable with the aperture ring.
Aperture operation: Manual (F2.8-5.6), automatic (F5.6-22).
Features:
Screwdrive AutofocusAperture RingFull-Frame SupportDiscontinued
Add Review of SMC Pentax-FA 28mm F2.8 Soft
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-1 of 1
5 users found this helpful
Lens Review Date: February 17, 2012 I can recommend this lens: Yes | Price: N/A | Rating: 9
Pros: Unique abilities
Cons: Aperture setting only shows up in EXIF data at certain openings
Sharpness: 9    Aberrations: 8    Bokeh: 9    Autofocus: 8    Handling: 8    Value: 9    New or Used: Used    Camera Used: K-5
Since there are no reviews for this lens, and it's somewhat uncommon, I thought I'd post a brief one. Although I've had it for almost a year, I haven't used the lens enough yet to give more detail. However, on World Pentax Day this year I did get a shot that convinced me the lens has real value.
Here's that shot:
https://www.pentaxforums.com/gallery/photo-theater-courtyard-32697/
And here are similar shots from the FA31/1.8 and K50/1.2 which demonstrate that a standard lens, even a fast one, can't achieve the same effect. I also doubt a soft filter would have the same effect either, although I can't say for sure, since I didn't try.
https://www.pentaxforums.com/gallery/photo-theater-courtyard-fa31-32699/
https://www.pentaxforums.com/gallery/photo-theater-courtyard-k50-1-2-32700/
If you click on the links below each photo, you can view them at a larger size - plus see additional comments that help in comparing the shots.
I rated the sharpness a 9, because when stopped down to f/8 or smaller it is sharp, demonstrating that it really is a sharp lens, just with a soft effect designed into it at wider apertures.
All times are GMT -7. The time now is 08:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
