Author: | | Site Supporter Registered: June, 2013 Location: Utrecht Posts: 25 | Lens Review Date: October 15, 2019 | I can recommend this lens: Yes |
Price: $40.00
| Rating: 9 |
Pros: | Compact, sharp and contrasty stopped down, hood | Cons: | red/greenish fringing wide open | Sharpness: 9
Aberrations: 7
Bokeh: 9
Handling: 10
Value: 10
Camera Used: K1ii, K-01 and film
| | This lens is a real surprise. Not in the same league as the K2.5/135 but decent sharp stopped down. At F4 there is a lot of green/red fringing in contrasty areas, almost gone at F5.6.
F8-F11 is the sweet spot for this lens for clean sharp pictures, even on full frame in the corners. As with most tele's, you have to correct the levels a bit in post because the lower contrast (stretch the diagram).
Low price, true build quality, portability and build in hood makes this lens a no-brainer. In good light situations I often grab this with me because it is so compact and sharp enough.
Pictures on Full Frame: | | | | | Pentaxian Registered: June, 2014 Location: Florida Posts: 1,906 | Lens Review Date: September 7, 2019 | I can recommend this lens: No |
Price: $50.00
| Rating: 6 |
Pros: | | Cons: | | Sharpness: 6
Aberrations: 7
Bokeh: 6
Handling: 9
Value: 5
Camera Used: k-01/KP
| | Maybe I've had bad copies, but after owning two of these I can't recommend it. Sharpness is poor on APSC no matter how much you try, and the images come out flat without any character. Contrast is bad, aberrations are mediocre at best, Bokeh is busy and not very pleasing.
I had actually tested this lens against my Tak Bayonet 135 f2.5, and the 135 is sharper than the 200 when cropped to 200mm equiv at F4-F8. Disappointing.
The only thing this lens has going for it in my opinion is the fact that it's an M lens in construction so at least it's nice to hold.
I'd suggest a hard pass on this. If you need long end performance on the cheap I'd recommend looking into the A70-210 or a non PLM 55-300.
If you need an M telephoto however (for some reason), while it isn't as long, the M75-150 is almost the same size while creaming this thing in performance even wide open.
| | | | New Member Registered: September, 2008 Location: Québec Posts: 12 | Lens Review Date: April 29, 2019 | I can recommend this lens: Yes |
Price: $40.00
| Rating: 9 |
Pros: | Small, Lightweight, Excellent Handling | Cons: | None | Sharpness: 9
Aberrations: 8
Bokeh: 9
Handling: 10
Value: 10
Camera Used: K5 - II s
| | Really surprised, sharp enough at f 11 . | | | | New Member Registered: February, 2016 Location: lake constance Posts: 1 | Lens Review Date: March 18, 2019 | I can recommend this lens: Yes |
Price: $50.00
| Rating: 10 |
Pros: | Light weighted, sharp, small | Cons: | none | Sharpness: 9
Aberrations: 9
Bokeh: 10
Handling: 10
Value: 10
Camera Used: Sony A7, Pentax MX, ME super
| | In my opinion this is a very interesting lens for general use on trips. Not too heavy and long. Good handling on MX and ME super. Digital use is perfect.
The built-in hood is very helpful, also on rainy days. Perfect mechanics and optical quality like my former Nikon AIS 4 200mm. But this lens is a real pocket tele with a much better coating.
Generally the coating of the smc lenses is better than the NIC and the later Nikon coatings on manual lenses.
I can completely recommend this tiny and solid lens, because you can get it for a low price in good condition. Its a pity, that you can´t get those lenses new anymore. The good old times. With the Pentax smc M 4 200mm you can bring back a little bit of that to your photograph. Enjoy it!  | | | | | New Member Registered: January, 2019 Posts: 14 | Lens Review Date: February 5, 2019 | I can recommend this lens: Yes |
Price: N/A
| Rating: 8 |
Pros: | | Cons: | Price, construction in relation to "K" ... | Sharpness: 7
Aberrations: 7
Bokeh: 7
Handling: 7
Value: 7
Camera Used: K-5II
| | The lens is only good. it is too expensive for its performance. better to add $ and buy a series of "K".
| | | | Junior Member Registered: October, 2017 Location: Lindsborg, Kansas Posts: 46 2 users found this helpful | Lens Review Date: October 9, 2018 | I can recommend this lens: Yes |
Price: $70.00
| Rating: 9 |
Handling: 10
Value: 10
Camera Used: Pentax K-70
| | A few months ago I purchased a used Pentax M 200mm f/4 lens. I had a gap in my lens line-up between 135mm and 300mm, so I figured this would be a cheap solution (it was only $70).
When the lens arrived it was in like-new condition, and a few test shots around town confirmed that the image quality was decent… but it really wasn't a lens that I expected to use a lot.
However, I recently had a soccer match to shoot that started at 1:00 PM on a blazing hot day with the sun almost directly overhead: miserable conditions for trying to get good pictures. Because I didn't have high expectations for the match I decided to shoot the first half with the 200mm, just to see what it could do. When I reviewed the shots later, I was astonished at the spectacular images that I got with it!
The lenses I usually use for field sports are the Pentax F* 300mm f/4.5 and the Rokinon 85mm f/1.4. Compared to these lenses, the 200mm is much smaller and lighter, and the improvement in handling is definitely noticeable. This ease of handling is one reason why the lens is working so well for me. And 200mm on a crop sensor (equivalent to 300mm on a full-frame sensor) is a really good focal length for field sports.
The 200mm is also surprisingly easy to focus; much easier than the 85mm despite that len's bright f/1.4 aperture. It's so easy to focus that, at times, it feels like I'm using an autofocus lens! It should be noted, however, that using manual-focus lenses for fast action is a skill that has to be learned. I spent 20 years honing that skill back in the film era, so what is easy for me probably won't be easy for someone who has only used autofocus lenses. But, if you are willing to put in the effort to learn to use it, this lens will certainly deliver great results.
This is rapidly becoming my favorite lens for field sports. Not too bad for a 40-year-old manual focus lens! | | | | New Member Registered: September, 2016 Posts: 3 2 users found this helpful | Lens Review Date: October 28, 2017 | I can recommend this lens: Yes |
Price: $60.00
| Rating: 9 |
Pros: | Great performer, even at F4 | Cons: | None at this price | Sharpness: 9
Aberrations: 8
Bokeh: 7
Handling: 10
Value: 10
Camera Used: Olympus OM-D EM-1
| | When I switched from Pentax to micro4/3 this together with the pentax m 50mm F1.7 were the only two lenses I kept. I had 10+ legacy lenses, most of them m-series. Though beautifully crafted, they were all made redundant by modern glass; the so very impressive olympus 12-40 mm F2.8 pro zoom together with Sigmas 60mm F2.8 prime.
This and the 50/1.7 couldn't be replaced, though.
I use it on the em-1 with a pixco focal reducer ("speed booster"). It's an optic adapter that concentrates the full frame image circle rendered by the lens into a smaller area, effectively reducing the focal length by a factor of 0,72 = 144mm. A positive side effect is that you also gain a full stop of light (google "focal reducer" for the theory behind all of this) turning the lens into an F2.8. In practice with micro4/3's x2 crop factor due to the smaller sensor, this lens then becomes a 144 x 2 = 288mm F2.8 full frame equivalent!
The whole package with camera+battery grip+lens weighs in at 1,200 grams. Compare that to a full frame Canon or Nikon 300mm f2.8, where the lens just by itself weighs twice as much!
As a last positive note, it looks pretty awesome mounted on the camera.
Image quality? Holds up very well compared to modern lenses, magnifications posted are 100% crops.
All of this at a price of $120 (lens+focal reducer). Sure I don't have AF, but a Canon L 300mm F2.8 costs $6,000. I'm very happy. | | | | Site Supporter Registered: July, 2016 Posts: 29 2 users found this helpful | Lens Review Date: August 8, 2016 | I can recommend this lens: Yes |
Price: $100.00
| Rating: 10 |
Pros: | In the right light it is perfect. | Cons: | none | Sharpness: 9
Aberrations: 9
Bokeh: 9
Handling: 9
Value: 10
Camera Used: k3ii
| | I cannot sing this lens' praises enough. I picked it up from a good lens dealer and it was in perfect shape. Everything worked wonderfully and it was light and compact enough that I could take it anywhere. Everything on the lens feels very well-made and premium.
Image-wise this is a perfect lens for its focal length. If you nail your focus correctly and stay within the lens' limits (don't try and shoot something half a mile away or some silliness) you will find no issues at all with your images. Being f4, it's faster than a lot of other old manual lenses and you will be surprised at just what you can shoot with the lens. I've done sports, birding, and landscapes with it - the key is nailing that focus.
For the money you won't find a better 200mm manual. I take it with me everywhere I go. | | | | Site Supporter Registered: May, 2015 Location: Hampshire Posts: 869 1 user found this helpful | Lens Review Date: May 19, 2016 | I can recommend this lens: Yes |
Price: $30.00
| Rating: 8 |
Pros: | It is a Pentax lens | Cons: | Not special enough | Sharpness: 8
Aberrations: 8
Bokeh: 8
Handling: 8
Value: 9
Camera Used: K-5
| | I was disappointed with my initial results with this lens. Using a 300mm lens on the birds in my back garden was a little unwieldy and I had liked some of the images provided by a Chinon 200mm F3.5 so when the opportunity came to get this at a good price I did.
It seems quite sharp through the apertures I have used this at, until cropping, the feather detail was not quite as sharp as the Chinon images which surprised me. Still, early days, tweak the camera settings and with better light.......
CA is better controlled by the Pentax, the Chinon shows more purple fringing and also some green. The Pen tax shows some red! Unless it's me.
I really wanted to give a lot of 10's for this lens, maybe my copy is not 100% as it left the factory. | | | | Pentaxian Registered: January, 2013 Location: Kansas City, MO Posts: 1,566 4 users found this helpful | Lens Review Date: April 2, 2016 | I can recommend this lens: No |
Price: $70.00
| Rating: 7 |
Pros: | compact, lightweight, sharpness, rendering | Cons: | contrast, color, all the inconveniences of a fixed focal length | | Here's my Flickr album with all of my images from this lens: CLICK HERE.
I bought it used from eBay, actually one of the first lenses I bought when I started my collection, but I've never really put it through its paces, and even after this (most) month, I still feel like I could learn some things about it.
It's a solid M lens, well constructed and responsive. Nicely dampened focus ring that goes on for miles and miles, so it was a little inconvenient to have to crank the thing around from infinity to MFD, when I was ever in that position. The aperture ring has half-clicks from 4 all the way up to 32, but I never stopped it down past f/16 for my purposes. The lens has a built-in slide-out hood, which did improve contrast noticeably. The hood on my particular lens is adorably and amateurishly engraved with the name "Wilber Havens". I'd like to know who he is, but I'm sure I'll never find out. ;-)
The lens doesn't disappoint with sharpness and rendering - it's a solid performer, but not remarkable. Contrast and color were not as dependable, but images responded well to PP. The CA was readily available in all high-contrast situations, but Lightroom knocked it down, and it was actually less intrusive at the most usable (or, at least, my most-used) apertures, f/5.6 to f/11. The bokeh was pleasant enough for me, when I could conjure it, but I'm not much of a bokeh connoisseur, so my opinion's not worth much.
The FOV was, frankly, shocking. I'm not a keen telephoto shooter and I gravitate more towards wide-normal lenses. I don't want to be stuck at 200mm for a month ever again! lol! But, to be honest, the lens was easy enough to handle and the MFD was graciously ~2m/6ft, which was pretty manageable.
Ultimately, I was not inclined to like the focal length, and I have no other fixed 200mm lenses to compare it to, so this was a pretty blind experimentation on my part. Mr. Havens may have loved the lens enough to get his name emblazoned on it for eternity, but if I am ever in a situation where I think I might need the extra reach of a telephoto, I'll definitely be packing my A70-210/4 or my Kalimar 60-300/4-5.6 before tying myself down to a fixed focal length, even with the dependability and build quality of the M lenses.
| | | | Veteran Member Registered: August, 2011 Location: Austin, Texas Posts: 302 | Lens Review Date: March 11, 2016 | I can recommend this lens: Yes |
Price: $75.00
| Rating: 9 |
Pros: | Image Quality, Build Quality, Size | Cons: | None | Sharpness: 9
Aberrations: 8
Bokeh: 8
Handling: 10
Value: 10
Camera Used: K-3 and MX
| | What a nice handling lens. Smooth focusing, balances very well on camera and SHARP. On the K-3 it is equivalent to a 300 f/4 without the size, you can put it in your bag and carry it all the time so you can reach out and grab those distant subjects when needed. Best at f/5.6 to f/11, not that it isn't just fine wide open. I still use my MX for black and white and now I wonder why I did not have this lens before. I recommend it highly, especially with the new FF K-1 coming out (you might look for an A version for shutter priority). Great addition to either my SMC-A set 24/35/50/135 or the DA set 15/35/70/18-135
| | | | Forum Member Registered: February, 2016 Location: Moab, Utah Posts: 90 2 users found this helpful | Lens Review Date: February 18, 2016 | I can recommend this lens: Yes |
Price: $80.00
| Rating: 9 |
Pros: | Sharp, color rendering, contrast | Cons: | bokeh | Sharpness: 9
Aberrations: 9
Bokeh: 8
Handling: 10
Value: 10
| | Typical perfect build quality and usage from the old Pentax primes. The military wishes they could build tanks this tough. Smooth and snappy like you expect and desire.
Very sharp. I don't keep lenses with soft corners and this is a definite keeper. Usable for most things at f4 (but you better be dead on critically focused) and tack razor crisp at 6.3 and smaller. I don't need the 2.8 at 200. There's never enough depth of field for anything I want to shoot, and any 2.8 lens I have ever used isn't actually usable at 2.8 anyway, so why bother carrying the extra 4x the weight? I suppose you look cooler with a 70-200 2.8, but aside from that, what are you actually gaining in usable images? At least that's how I feel. Sports shooters will likely disagree for focusing reasons, but then they aren't using manual focus lenses as first choice are they. With live view and super sensors of modern cameras, there's no need for f2.8 for almost anybody. This lens is a serious bargain for under a hundred bucks and will help you get higher quality images than you ever could with a modern, haphazardly constructed zoom.
| | | | New Member Registered: September, 2015 Posts: 2 1 user found this helpful | Lens Review Date: September 20, 2015 | I can recommend this lens: Yes |
Price: $50.00
| Rating: 9 |
Pros: | small, solid, crisp, built-in hood, overall very good lens. | Cons: | none, just a little CA full aperture. | Sharpness: 9
Aberrations: 9
Bokeh: 9
Handling: 10
Value: 10
Camera Used: Pentax ist DS
| | This is a tipical old school Pentax M lens: well built, lightweight, nice optical scheme, sweet colour and contrast.
I used it tipically on wild animals (African photosafari...) and everytime you need a lightweight gear.
Best shots I get with it is full aperture; subject remain very crisp with a smooth, creamy background... just nice!
Cromatic aberration is noticeable at f4 (especially on luminous background), but is not a real issue.
An overall very good lens, I've found it withstands comparison against the venerable Takumar 200mm f3.5 (which is probably
2-3 times higher priced...). Use it with built-in hood for a better flare protection and contrast improvement.
| | | | Pentaxian Registered: September, 2010 Location: MD Posts: 935 1 user found this helpful | Lens Review Date: July 18, 2015 | I can recommend this lens: Yes |
Price: $38.00
| Rating: 9 |
Pros: | compact, solid, built-in lens hood, Pentax M character | Cons: | needs f5.6 or greater | Sharpness: 8
Aberrations: 8
Bokeh: 9
Handling: 9
Value: 9
Camera Used: K-30
| | Typical Pentax M prime lens with all it's delicious characteristics. Solid and smooth, and I appreciate the built-in lens hood.
At f4, it's almost not worth using since I got soft, glowing images with lots of green CA. Much improved one click down (5.6) and best at f8 +/- a step or so. Still quite nice at f16. Compared to my DAL 55-300 shot at 200mm, it may not be quite as sharp or contrasty, but it's a bit better across the frame. Attached pics (sorry for cat pics ) have minimal pp. | | | | Veteran Member Registered: December, 2010 Location: SoCal Posts: 515 | Lens Review Date: May 17, 2015 | I can recommend this lens: Yes |
Price: $35.00
| Rating: 9 |
Pros: | relatively small/light, solid, inexpensive, large focus range | Cons: | complete manual | | Good deal on a lens... lots of PF in outdoor light.
