Pentax Lens Review Database » Pentax 67 Medium Format Lenses » 67 Telephoto Primes
S-M-C Takumar 6x7 / Super Takumar 6x7 200mm F4 Review RSS Feed
Sharpness
 9.0
Aberrations
 8.7
Bokeh
 8.3
Handling
 8.3
Value
 10.0
8 46,422 Tue September 21, 2021
100% of reviewers $126.43 8.25
Description:
This is the original 200mm. It came in two variants with the same optics and dimensions:
© www.pentaxforums.com, sharable with attribution | Check camera compatibility
Image Format
6x7
Lens Mount
Pentax 6x7
Aperture Ring
Yes (no A setting)
Diaphragm
Automatic, 8 blades
Optics
4 elements, 4 groups
Mount Variant
Inner Bayonet
Max. Aperture
F4
Min. Aperture
F22
Focusing
Manual
Min. Focus
250 cm
Max. Magnification
0.1x
Filter Size
67 mm
Internal Focus
26 ° / 19.9 °
Hood
Built-in, slide out
Case
Lens Cap
Coating
Weather Sealing
Other Features
Diam x Length
91.5 x 120 mm
Weight
900 g
Production Years
1969 to 1971
Notes
Engraved name: SUPER-TAKUMAR/6x7 1:4/200
User reviews
Variants
1969: Super TAKUMAR/6x7 1:4 200mm (this lens)
1971: Super-Multi-Coated TAKUMAR/6x7 1:4 200mm
Super-Multi-Coated Takumar 6x7 200mm F4
Image Format
6x7
Lens Mount
Pentax 6x7
Aperture Ring
Yes (no A setting)
Diaphragm
Automatic, 8 blades
Optics
Mount Variant
Inner Bayonet
Max. Aperture
F4
Min. Aperture
F22
Focusing
Manual
Min. Focus
250 cm
Max. Magnification
0.1x
Filter Size
67 mm
Internal Focus
26 ° / 19.9 °
Hood
Built-in, slide out
Case
Lens Cap
Coating
SMC
Weather Sealing
Other Features
Filter Bayonet
Diam x Length
91.5 x 120 mm
Weight
900 g
Production Years
1971 to 1986
Notes
Engraved name: Super-Multi-Coated TAKUMAR/6x7 1:4/200
User reviews
Optics unchanged from Super TAKUMAR version
Variants
1971: Super-Multi-Coated TAKUMAR/6x7 1:4 200mm (this lens)
Features:
Manual FocusAperture RingMedium-Format SupportAdapter needed for DSLRsDiscontinued
Price History:
Add Review of S-M-C Takumar 6x7 / Super Takumar 6x7 200mm F4
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-8 of 8
Review Date: September 21, 2021 Recommended | Price: $65.00 | Rating: 10
Pros:
Cons:
Sharpness: 9    Aberrations: 8    Bokeh: 9    Handling: 9    Value: 10    Camera Used: 645Z
Bought a low priced sample from Ebay, want to have a big 67 lens in my collection. Bought the Pentax 645 adapter, put it on my 645Z and it worked, adjusted exposure based on manual changes of the aperture. I got it for $40 with $25 shipping from Japan to USA
Only did test shots, but I wanted to have a recent price to database
Review Date: April 7, 2015 Recommended | Price: $60.00 | Rating: 6
Pros: Value priced, in focus sharp, pleasing bokeh, solid construction
Cons: Heavy fringing, bit contrastier than I'd like, heavy
A value-priced short telephoto for the 6x7 that's possible to hand-hold with faster film or wider apertures. (Downside is that you'll either need very bright light, very high speed film, or working towards the wider aperture range.)
Downside is that it fringes badly. Magenta fringing in OOF areas and bright light. Perhaps best for B&W work.
Loyal Site Supportaxian
1 user found this helpful
Review Date: November 30, 2013 Recommended | Price: $80.00 | Rating: 9
Pros: Inexpensive, sharp, Well suited to Astrophotography
Cons: OOF CA Green/Magenta
Sharpness: 8    Aberrations: 9    Bokeh: 8    Handling: 7    Value: 10
If you are looking for a relatively inexpensive lens for astro work, you've found it. I've never used it on a MF camera, so my review is only for using it on smaller format cameras. I read that this was a good lens for astrophotography, so I picked one up to use on a Full-Frame and APS-C 35mm cameras. I was not disappointed.
On a APS-C sensor, the stars are pinpoint from corner to corner at F4. As another reviewer already mentioned, color tonality is exceptional in this role. (One of the most difficult aspects of getting good astro shots is keeping all the stars from clipping the color channels (which degrades the saturation) and this lens does a better job than anything short of a pricey telescope or much more expensive lenses.) Field illumination is also very even - hardly any vignette at all. Of course, I 'm using the lens in its "sweet spot", but this is really important when you're doing deep-sky shots and a little vignette is often the difference between getting enough picture data to make a good stitch with or not. Mechanically it's easy to make critical focus with. If you're mating this with a dedicated CCD or DSLR, there's enough room to fit a filter wheel between the lens and camera. If you using something like the Pentax P-Adapter (6x7 to M42) to fit it to your dslr, you can take advantage of the fact that the adapter has internal 49mm threads, and therefore you can use a 49->48mm stepdown ring to enable use of your astronomical filters.
A solid value, as these are readily available online for good prices.
Giveaway winner!
Review Date: November 22, 2010 Recommended | Price: $100.00 | Rating: 9
Pros: very sharp, well behaved in glare conditions
Cons: a little far sighted
Sharpness: 10    Aberrations: 9    Bokeh: 8    Handling: 9    Value: 10
This is a sharp lens and I've had very good results from it. The common complaint is the close focus being not all that close. That is more a minor point for me and I am more out to 8-15 feet for many shots so far, so I've not had the frustration as some do. I found this focal length to still allow me to get away with handheld shots and though the f4 is not fast, it is still sharp enough (bright indoors). This is a very good lens so far and I hope I don't find too many negatives along the way.
Update: Well found a point where I'll agree. Small nephew... couldn't quite manage the right framing for a portrait... yes, not close enough. Lucky thing I had my extension tubes to play with and he was willing to stand there.
Review Date: November 7, 2010 Recommended | Rating: 8
Pros: sharp, built quality
Cons: some green CA, sensor flare
Hi,
this review is based on the use on my K20D, it's a sharp lens , not spectacular but sharp enough for most use from f/5.6. The problem is that there is some green CA in OOF background, if you use it for landscape it shouldn't be a problem since you will stop it down for DOF. The thing that bugs me is sensor flare, especially in long distance shots on an overcast day when stopped down.
Because of those 2 things i gave it an 8. Still a good lens.
Review Date: November 29, 2009 Recommended | Price: $180.00 | Rating: 9
Pros: Solid - ex. contrast and colour saturation - takes 67mm filters
Cons: Tad heavy - price for being solid & well built.
I rated this a 9 - even though it lacks the close focus distance like that of the updated version. I use the 165 lens for portraits, so the closer focus is not that much of an issue for me. The older version shares the 67 mm filters with the 90, 135 & 165 lenses. The newer version uses a 77mm filter, so more stuff to carry.
The older design has a natural feel when on the camera. The glass and coatings used gives an extra richness to the colours - compared to the newer 200 version. My friend now has this lens and has taken a number of astro photos with it shot wide open at f4. A small amount of vignette at the corners - to be expected wide open - as shooting tiny pin points of light and faint nebulae are very demanding on a lens.
He has also shot astro frames with various other Pentax lenses, but the results from this older 200 lens left us stunned. The colour saturation and tonality of the stars - especially the gold, red / orange giants, was incredible. The blue and pure white stars were no exception, filling the frame with a veritable feast of colours for the eyes. None of the other lenses have reproduced the colour saturation and tones captured with this lens to date.
I have since replaced this lens with the newer design. It's lighter, very sharp, closer focusing, a great lens, but does not have the feel or tonal quality of the older lens. Photos of sunsets, especially the gold reflections in water of a yellow / orange sun will show the differences between the two versions. Yes, I'm thinking of going back to the older version.
Just be aware as this Takumar lens, as well as other lenses will reach critical focus before the infinity stop on the lens. I have proved this with with my 300 lpi Ronchi screen on my Stiletto focuser using a brighter star at night. Critical focus was achieved about the middle of the infinity symbol where the mark pinches in.
This is necessary with astrophotography where the atmosphere and angle on the horizon, plus use of filters, will change critical focus. It is rarely right against the infinity stop on the lens. I believe this was intentionally designed by Pentax, for the astrophotographers.
Review Date: February 20, 2009 Recommended | Price: $200.00 | Rating: 6
Pros: sharp and inexpensive
Cons: Not close enough focusing for portraits
The fact this lens didn't close focus for me was an issue. I replaced it with the newer version.
2 users found this helpful
Review Date: February 5, 2009 Recommended | Price: $200.00 | Rating: 9
Pros: very good sharpness, flares well controlled, perfect and solid build quality
Cons: only that minimal focus is about 2,5 meters
I really love this lens. It is very sharp and very good against the sun.
Itīs a passion taking pictures with this lens. Depth of field is very narrow, it can be beautifully used in pictures with small DOF.
Outstanding in direct sunlight , 8 aperture blades = 8 starbursts:
All times are GMT -7. The time now is 11:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
