Pentax Lens Review Database » Pentax M42 Screwmount Lenses » M42 Screwmount Extreme Telephoto Primes
Takumar 500mm F5 Review RSS Feed
Takumar 500mm F5
2 24,553 Sun May 22, 2011
50% of reviewers $312.50 7.00
Takumar 500mm F5
Takumar 500mm F5
Takumar 500mm F5
Takumar 500mm F5
Description:
This lens, which came in two production versions, was originally produced in 1957. Non-removable tripod collar. Rack and pinion focusing. Filters attach to the rear of lens. The photos show the late model.
Takumar 500mm F5 (early)
Image Format
Full-frame / 35mm film
Lens Mount
M42
Aperture Ring
Yes
Diaphragm
Manual
Optics
2 elements, 1 groups
Mount Variant
M42 Plain
Check camera compatibility
Max. Aperture
F5
Min. Aperture
F22
Focusing
Manual
Min. Focus
1050 cm
Max. Magnification
0.05x
Filter Size
46 mm (Rear drop-in)
Internal Focus
APS-C: 3.3 ° / 2.7 °
Full frame: 5 ° / 4.1 °
Hood
Built-in, slide out
Case
Lens Cap
Coating
Weather Sealing
Other Features
Rear Filter Mount
Diam x Length
Weight
2850 g
Production Years
1957 to 1961
Engraved Name
Takumar 1:5/500
Reviews
User reviews
Notes
Non-removable tripod mount. Rack and pinion focusing. Filters attach to the rear of lens.
Variants
1. Takumar 500mm F5, chrome and black finish (this lens)
2. Takumar 500mm F5, all black finish
Takumar 500mm F5 (late)
Image Format
Lens Mount
M42
Aperture Ring
Yes
Diaphragm
Manual
Optics
Mount Variant
M42 Plain
Max. Aperture
F5
Min. Aperture
F22
Focusing
Manual
Min. Focus
1050 cm
Max. Magnification
0.05x
Filter Size
Internal Focus
Hood
Built-in, slide out
Case
Lens Cap
Coating
Weather Sealing
Other Features
Rear Filter Mount
Diam x Length
Weight
2850 g
Production Years
1961 to 1965
Engraved Name
Takumar 1:5/500
Product Code
326, 43260
Reviews
User reviews
Notes
The rear of the lens detaches (bayonet) to ease mounting on camera.
Variants
2. Takumar 500mm F5, all black finish (this lens)
Features:
Manual FocusAperture RingFull-Frame SupportAdapter needed for DSLRsDiscontinued
Price History:
Add Review of Takumar 500mm F5
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-2 of 2
Lens Review Date: May 22, 2011 I can recommend this lens: No | Price: $350.00 | Rating: 6
Pros: Fast for a 1957 lens
Cons: Vignetting on 24x36
I would not have expected such quality from a simple doublet lens. It suffers from some vignetting on 24x36 at the greatest apertures. Good for sunsets. Bokeh seems to be interesting. This is a rack and pignon focusing system lens, that allows a quick focus when you are used to this system. The rear part is removable.
I would not recommend it to a user because the 500/4.5 is not extremely expensive compared to it and is slightly better, but if you can get it for, let's say, $300 or less, this can be a good solution.
Some samples on 24x36 : http://kajiwara.weebly.com/takumar-5005.html
Lens Review Date: February 26, 2007 I can recommend this lens: Yes | Price: $275.00 | Rating: 8
Pros: fast, strong construction
Cons: heavy, wobbly sunshade
Just recently purchased this, no chance to use in detail. One real surprise here is this did some daylight shots hand-held with 100 ASA film (the analog kind!). The fast speed allows lots of lattitude in depth of field. Somewhat stiff focusing, although I prefer that.
All times are GMT -7. The time now is 12:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
