Pentax Lens Review Database » Pentax M37 Screwmount Lenses » M37 Screwmount Prime Lenses
Takumar 50mm F3.5 Review RSS Feed
Takumar 50mm F3.5
Sharpness
 9.0
Aberrations
 8.7
Bokeh
 9.0
Handling
 7.7
Value
 8.7
4 22,658 Thu August 12, 2021
100% of reviewers $128.33 8.50
Takumar 50mm F3.5
Takumar 50mm F3.5
Takumar 50mm F3.5
Takumar 50mm F3.5
Description:
This standard lens of Tessar type was introduced in 1952. It came in two variants:
1) With a manual diaphragm (first photo)
2) With a pre-set diaphragm (second photo)
Name engraved on lens: Asahi-Kogaku Takumar 1:3.5 f=50mm
WeightDiam x LengthFilter SizeMin. Focus
180 g32 mm2.5 ft
Diagonal FoV (24x36)Horizontal FoV (24x36)Min. ApertureMax. Aperture
46 degrees39.5 degreesf/16f/3.5
Diagonal FoV (APS-C)Horizontal FoV (APS-C)DiaphragmOptical Construction
32 degrees27 degreesPre-set4 elements in 3 groups
Distance scale in feet only
Features:
Manual FocusAperture RingFull-Frame SupportAdapter needed for DSLRsDiscontinued
Price History:
Add Review of Takumar 50mm F3.5
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-4 of 4
Review Date: August 12, 2021 Recommended | Rating: 8
Pros: Black front ring
Cons:
Sharpness: 8    Aberrations: 8    Bokeh: 8    Handling: 7    Value: 8
Just to show the third version of the Takumar 1:3.5 f= 50 mm for Asahiflex
Review Date: January 2, 2017 Recommended | Price: $65.00 | Rating: 9
Pros: Sharp, Bokeh, Tiny
Cons: So small it affects handling
Sharpness: 9    Aberrations: 8    Bokeh: 9    Handling: 6    Value: 8    Camera Used: Olympus EM10
I've only had this lens for 2 days, but I was astonished at its performance. It's tiny, which is both good and bad. You don't mind taking it with you because it takes up very little space. It's 1.5"deep (including the mount) by 1.8" in diameter. But its small size makes it a little difficult to operate, mostly the aperture setting, which is set by turning the very front of the lens to your preset setting, and that's only an 1.25" in diameter. It's not heavy, but it does have some heft to it for its small size. I feel I got it at a bargain as it is in very good condition. It came with the leather case, which was in outstanding condition for its age, the M37-M42 adapter ring and an M42- PK mounting adapter. It did come with caps but not the original caps. Excellent Takumar build quality. Love the 12 blade aperture.
I found the lens to be very sharp with only the extreme edges and corners being a little soft at f5.6. Here are a few examples.
1 user found this helpful
Review Date: January 27, 2016 Recommended | Price: $220.00 | Rating: 10
Pros: VERY VERY SMALL and VERY SHARP
Cons: None
Sharpness: 10    Aberrations: 10    Bokeh: 10    Handling: 10    Value: 10    Camera Used: Asahiflex IIa, K3, K5
I thought this lens was bigger, but it is just like one of those Leica pancakes. It is almost difficult to use because of the smallness. However, it is a great lens. Once you learn to preset the aperture, then focus and stop down to the chosen aperture, you get wonderful photos. I will be posting some. I now have my complete Asahiflex lens collection, yes, all four of them. Well, I am not interested in the 5th one, too long!
HERE ARE SOME SAMPLES TAKEN WITH THE ASAHIFLEX IIa: (Tri-X developed with TmaxDev)
Spotmatic Black by Palenquero Photography, on Flickr
San Juan Capistrano by Palenquero Photography, on Flickr
San Juan Capistrano - De Los Rios Street by Palenquero Photography, on Flickr
Asahiflex by Palenquero Photography, on Flickr
DIGITAL SAMPLES
Here are some samples wide open (f/3.5) and at f/8. You judge them. I did not find any leakage of light on the new digital cameras. I did some test and placed a thick rubber band at the joint and did not get any leaks.
Hybiscus by Palenquero Photography, on Flickr
Tangerines by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f8-K3-Mandarinas by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f8-K3-DoNotEnter by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f8-K3-Depot by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f8-K3-ChocxoCafe by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f3.5-K3-Tangerines by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f3.5-K3-Mandarinas by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f3.5-K3-DoNotEnter by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f3.5-K3-Depot by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5@f3.5-K3-ChocxoCafe by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5-K3-Hybiscus1a by Palenquero Photography, on Flickr
Asahi-Kigaku Takumar 50mmf3.5-K3-Hybiscus1 by Palenquero Photography, on Flickr
Review Date: May 22, 2011 Recommended | Price: $100.00 | Rating: 7
Pros: Tiny and light lens
Cons: Slow
Even being one of the oldest Pentax lenses, this lens has good qualities. Optically, it is very similar to the Industar 50-2 50/3.5, I compared them and did not notice any difference apart from the parture blades (7 on the russian, 12 on the japanese). Stronger built than the russian one (160g vs. 100g). It has the typical Tessar signature.
Some samples and more details : http://kajiwara.weebly.com/takumar-5035.html
All times are GMT -7. The time now is 11:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
