Pentax Lens Review Database » Pentax 645 Medium Format Lenses » 645 Wide-Angle Primes
HD Pentax-D FA 645 35mm F3.5 AL [IF] Review RSS Feed
Sharpness
 9.7
Aberrations
 8.7
Bokeh
 9.7
Handling
 9.7
Value
 8.3
3 28,404 Sun July 1, 2018
100% of reviewers $1,599.33 9.67
Description:
Extreme wide angle lens for the 645 format. This lens was introduced in 2015 and replaced its FA counterpart. It retained the optical design of the FA lens but with some tweaks of the aspherical elements and the aperture blades became rounded for a nicer bokeh.
The lens elements are now HD coated for increased contrast and reduced flare and ghosting. The front element has SP coating which repels water and grease.
The lens has an aperture ring which makes it fully backwards compatible with 645 film cameras.
The petal-shaped bayonet lens hood has a removable piece which makes it easier to adjust a circular polarizer.
Image Format
645 film
Lens Mount
Pentax 645
Aperture Ring
Yes (A setting)
Diaphragm
Automatic, 9 blades (rounded)
Optics
10 elements, 7 groups
Mount Variant
645 AF
Check camera compatibility
Max. Aperture
F3.5
Min. Aperture
F32
Focusing
AF (screwdrive)
Quick-shift
Yes
Min. Focus
30 cm
Max. Magnification
0.25x
Filter Size
82 mm
Internal Focus
Yes
645 Digital: 76 ° / 64 °
645 Film: 90 ° / 77 °
Hood
PH-RBE 82 bayonet
Case
S120-150
Lens Cap
Plastic clip-on
Coating
HD,SP
Weather Sealing
Other Features
AF/MF Switch
Diam x Length
88 x 90 mm (3.5 x 3.5 in.)
Weight
570 g (w/o attachments) (20.1 oz.)
Production Years
2015 to present (in production)
Pricing
$1596 USD current price
$1599 USD at launch
Engraved Name
HD PENTAX-D FA 645 1:3.5 35mm AL[IF]
Product Code
26450
Reviews
User reviews
Notes
Two aspherical elements, one high refractive index low dispersion element.
Features:
Screwdrive AutofocusQuick ShiftInternal FocusingAperture RingAutomatic ApertureMedium-Format SupportAdapter needed for DSLRs
Purchase URL: Buy the HD Pentax-D FA 645 35mm F3.5 AL [IF]
Price History:
Add Review of HD Pentax-D FA 645 35mm F3.5 AL [IF] Buy the HD Pentax-D FA 645 35mm F3.5 AL [IF]
Sort Reviews by: Date | Author | Rating | Recommendation | Likes (Descending) Showing Reviews 1-3 of 3
4 users found this helpful
Review Date: July 1, 2018 Recommended | Price: $1,600.00 | Rating: 10
Pros: Sharpness
Cons: --
Sharpness: 10    Aberrations: 10    Bokeh: 10    Handling: 10    Value: 10
I just got this D-FA 35mm and I have the oldest one, the A 35mm.
The oldest one is a great lens and I was very afraid to get the new one.
And, what I have to say, now, is: The new one is superb. Period.
The new one is sharper at the center and sharper at the corners.
The sharpness of the oldest at F8 is almost the sharpness of the new one at 3.5 !!!
When we use the new onr at F8, it is becames the best overall experience I ever saw on a Medium Format (And I been using a Hasselblad H3D, before this one)
By overall I mean, the combination of Pentax metering, autofocus, white balance and TTL
The CA of the new one is minimal to zero.
As any medium format lens, this lens should be used stopped down. Around F8 is great.
I been using mine with a Hoya HD3 polarizer and it's a perfect pair.
5 users found this helpful
Review Date: January 9, 2017 Recommended | Price: $1,599.00 | Rating: 10
Pros: super sharp
Cons: pricey
Sharpness: 10    Aberrations: 9    Bokeh: 9    Handling: 9    Value: 8    Camera Used: 645Z
It's a winner. My rating is a solid 9.5 but rounding up in the absence of 1/2 point scores.
My favorite lens for the 645D and Z has been the A35 for it's amazing IQ, well controlled aberrations, and value price in the $300 neighborhood. On a whim, I decided to take a chance on the recent upgrade to the D FA version and am pleasantly surprised.
Having the benefit of doing some side by side comparisons to the A35, I am confident this lens is even better than the trusty older lens. Center sharpness is very good at f/3.5 and then by f/5.6 is excellent. Falls off above f/11 as might be expected. Flare handling is just fine when shooting into the sun or a strong oblique light source.
I happen to use 82mm polarizers for my 300mm, so the larger filter size is not a deterrent.
Overall, I am happy to have this one in my bag.
Here's one wide open:
Fern & Trunk
Rat Rock Island
Twenty One
More DFA35 pics here: https://www.flickr.com/photos/mikeoria/albums/72157666812125830
Review Date: September 20, 2016 Recommended | Price: $1,599.00 | Rating: 9
Pros: Fairly light and small, good focus
Cons: 82mm filter, some noticable lateral CAs
Sharpness: 9    Aberrations: 7    Bokeh: 10    Handling: 10    Value: 7    Camera Used: 645Z
The first sample of this lens had unacceptable lateral CAs. The replacement still has more CAs than I would like under the most difficult conditions, and more so with slightly out of focus black to white edges. But in most real world scenes not overly noticable and can be corrected in post-processing. Sharpness is however very good overall and exceptional at abut f/8 is and softening notably by f/16. I shot a series of landscapes at f/11 and was happy printing these 44" wide directly out of lightroom. I have also been pleased with colour, and contrast. Flare and ghosting appear to be well in control from limited examples.
This is not a particularly large lens (570g and about 90mm length/width). Comfortable to use on the 645z. Certainly not light, but carrying it about on the camera (around neck and in hand) for a couple of hours was no problem. The auto/manual focus switch is actually a clutch (no full-time manual focus while in AF) switching manual to AF is by by pulling/pushing the textured focus ring at the end (which took some finding out without an instruction book). In manual action is smooth and I had no difficulty achieving acurate manual focus in live view. I have not found it necessary to make any micro adjustments for focus.
This is a 35mm lens (For the 645d/z that is equivalent to 27.5mm on 35mm full frame). That is wide but not excessive and very usable but the price seems a little high particualrly at UK prices that are pound for dollar and therefore about 25% more expensive than USD. I often shot at 24mm on my DSLR so this is not quite as wide as I am used to, but the two wider Pentax lenses costs a lot more so I'm simply learning to work with the restiction.
Shooting at f/11 there is some barrel distortion, but you probably only want to correct it if there is something that makes it stand out. I cannot report if distortions are better than the predecessor. Exposure does fall of a small amount towards the corners. I have not measured it but it is perhaps just a small fraction of a stop and barely noticable in good lighting. Lightroom has a profile for the lens and handles the adjustments fine.
The filter thread is 82mm, which is slightly annoying since 77mm is far more common, and looking at the front element I can't help think there was no real need for this diameter. This isn't a problem for the square filter sets (just a minor expendature on a new wide angle Lee 82mm adapter) but it can be helpful to use the right size polarizer so it can fit inside the supplied lens hood, so more expendature for many people, but if you are buying an expensive lens you want top quality filters to go with it! The lens hood does have a removable section at the bottom so you can turn the filter and the cap can easily be removed an replaced with the hood in place.
The lens arrived with hood, cap and pouch but strangely this lens did not come with an instruction manual which I assume was an oversight.
All times are GMT -7. The time now is 03:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
