Author: | | Pentaxian Registered: June, 2013 Location: Washington DC Posts: 602 | Lens Review Date: December 21, 2019 | I can recommend this lens: Yes |
Price: $400.00
| Rating: 10 |
Pros: | 17.5mm in a package this small -- exclamation point! | Cons: | none | Sharpness: 8
Aberrations: 8
Bokeh: 8
Handling: 8
Value: 10
Camera Used: Q7
| | I rated Sharpness, Aberrations, Bokeh, Handling all at 8 because because those characteristics are essentially irrelevant given the sensor sizes of the Q cameras, and the small camera bodies ("Handling"?). I don't worry about any of those factors with the Q-system and this lens. But those characteristics are even more irrelevant with respect to the characteristic that matters: value. Value not in dollars, but rather in accessible ultra-wide zoom in such a ridiculously small size. In 2019, I still do not know what beats the Q-system with this and the 06 tele-zoom. As for sharpness, this lens is as good as it gets on the sensors in the Q's. Bokeh is impossible: shoot in BC mode if you need that, but, really, just bokeh in post if you need that. This lens is crazy unique, which alone makes it crazy good.
| | | | | New Member Registered: March, 2014 Location: New York Posts: 13 | Lens Review Date: April 20, 2019 | I can recommend this lens: Yes |
Price: $358.00
| Rating: 8 |
Pros: | Size/weight, IQ, close minimum focus distance | Cons: | Price, only f/3.7-4 max aperture | Sharpness: 9
Aberrations: 8
Bokeh: 7
Handling: 9
Value: 8
Camera Used: Q7
| | I put off getting this one until a couple of weeks ago because I wasn't sure I'd use it enough to justify the price. Its range does overlap somewhat with the 02 lens, which I already have. Finally decided to get it because everyone seems to have much good and very little bad to say about it, and because I no longer have anything wider than 24mm for any camera I own.
And yes, I'm glad I now have it, although I'm also still well aware that it won't be an everyday lens. On the Q7 its range is roughly 17.5mm to 27.4mm. For me it'll be primarily useful for travel, I should think.
What I like best about it is that it seems to offer good IQ overall (although not always at the corners, wide open) and focuses quite closely. This latter point can sometimes overcome the issue of not having a very large maximum aperture: if the subject is quite close, you can use the Blur Control setting to get rid of intrusive background messiness instead of shooting aperture priority as wide as possible. I had not really found a use for Blur Control before now, so this makes me happy.
The cat photo is the first one I took with the lens. Both are SOOC.  | | | | Veteran Member Registered: November, 2012 Posts: 963 | Lens Review Date: January 7, 2017 | I can recommend this lens: Yes |
Price: $230.00
| Rating: 10 |
Pros: | Small yet sharp, impressive rendition | Cons: | No included hood in the package | Sharpness: 10
Aberrations: 9
Bokeh: 6
Handling: 9
Value: 9
Camera Used: Q7, Q
| | This is an impressively, amazing lens.
I wasn't a believer, and honestly, got a bit scared of the brand new price. When a $230 almost mint, but torn box came out in a second hand market, I immediately arranged to grab it.
After a few test shots, I believe that this is the perfect lens for the Q system. It's as sharp as the 01, yet incredibly small for an ultra wide.
It's almost unbelievable how Pentax has made such a marvelous feat of a lens!
Now, if only Ricoh did not scrimp on a hood.
With a 06 on Q, and 08 on Q7, and 01 on standby, I'm all set.
| | | | Senior Member Registered: August, 2012 Posts: 118 | Lens Review Date: October 25, 2016 | I can recommend this lens: Yes |
Price: $208.00
| Rating: 9 |
Pros: | Size, weight, IQ, filter size | Cons: | too much overlap in zoom range with 02 | Sharpness: 9
Aberrations: 9
Bokeh: 6
Handling: 9
Value: 9
Camera Used: Q-7, Q-S1
| | This is a high performance lens with a high fun factor.
If you don't like ultrawides don't even think about getting this.
The bokeh is pretty much non-existent unless you are really close.
The JJC hood works perfectly and allows you to keep a lens cap on.
It would be nice it if it had a bit wider FOV at the wide end and a little less at the long end.
I agree with Wolfhorn - it has better edge sharpness than the 16-50 at 16mm
This lens almost eliminates the need for the 03 fish-eye and the 04 toy wide lenses.
It you have two bodies, this and the 06 are an unbeatable combo.
It is starting to show up on the used market now at lower prices.
| | | | | New Member Registered: May, 2015 Location: Melbourne Posts: 1 1 user found this helpful | Lens Review Date: February 27, 2016 | I can recommend this lens: Yes |
Price: $400.00
| Rating: 10 |
Pros: | compact, fantastic corner sharpness, great colour reproduction , minor distortion | Cons: | not really | Sharpness: 10
Aberrations: 10
Bokeh: 9
Handling: 10
Value: 10
Camera Used: Q7
| | I was a bit hesitating before purchasing this lens due to the steep pricing (nearly cost as much as I spent on 01+02+06 all together). However, once I received my copy and started shooting with it, all my concerns went away. What a lens! It is certainly compact, quite a bit smaller than 02 or 06 lens. The amazing thing is the IQ, corner sharpness smashed my DA* 16-50. In fact, it is one of the sharpest wide angle lens I have ever seen. Colour reproduction is great, which makes RAW file super easy to work with. To sum up, for any one who owns a Q system camera, this lens is a must_have!  | | | | Loyal Site Supporter Registered: January, 2008 Location: Paris, TN Posts: 3,247 | Lens Review Date: June 22, 2015 | I can recommend this lens: Yes |
Price: $390.00
| Rating: 10 |
| I don't claim much experience with WA lenses but I can agree with all the good things said in previous reviews. I have no "Yes, but..." critical comments to add.
I've shot with the Sigma 10-20's, the Tamron 10-24 and the DA 16-45 -- this one is at least the equal for IQ.
But to really appreciate this lens you have to place it in context with the Q- bodies. It is simply gonna BE THERE when any of my other APS-C DSLRs and WA lenses would have been too burdensome to bother with.
It packs light and small enough to be with you when nothing else in that FL range would fit. Adding the 01, 03 and 06 for a full system kit doesn't take up the space of a really good sandwich in a fanny-pack.
The price seems high at first but it shouldn't because the results you'll get in the field match any of the better WA lenses available IMLE.
I screwed up the other day - thought I had either the DA 18-135 or the AF SP 70-200 with me. Turned out to be the DA*300 prime and the Q7+08 saved the day.
| | | | New Member Registered: January, 2015 Posts: 14 | Lens Review Date: March 22, 2015 | I can recommend this lens: Yes |
Price: $500.00
| Rating: 10 |
Pros: | small wide angle zoom with excellent quality | Cons: | cost | Sharpness: 10
Aberrations: 9
Bokeh: 8
Handling: 9
Value: 9
| | Excellent little wide angle zoom. Very flare resistant (excellent for a zoom, much better than the 12-24mm). Low field curvate, sharp from corner to corner. Best f.stop is f.4.5 (3,8 mm), respectively f.5,6 (5.9 mm). I used this lens on a Q7.
| | | | Moderator Site Supporter Registered: February, 2012 Location: Adelaide Hills, South Australia Posts: 10,169 1 user found this helpful | Lens Review Date: January 31, 2015 | I can recommend this lens: Yes |
Price: $450.00
| Rating: 9 |
Pros: | Size, 49mm filter thread, IQ | Cons: | Bokeh (duh!), cost | Sharpness: 9
Aberrations: 10
Bokeh: 7
Handling: 9
Value: 8
| | I have just finished using this lens daily for a month in the Single In challenge. Images can be viewed HERE
It is WIDE!! And rectilinear(ish), and it focusses really close. The control rings are smooth; the manual focus ring is a bit fiddly for my big mitts, but in most cases the AF is awesome so that doesn't really matter. It sticks out less from the camera than the 02 Standard Zoom, but it is significantly thicker, which is a *good* thing. Why? Because it takes Pentax-friendly 49mm filters! I had one episode of HIDEOUS flare, but most of the time if the sun was in the frame it wasn't a biggie. The after-market hood seems to work.
It's pretty sharp from the get-go, and chromatic aberration is virtually non-existant. The aspherical element may actually be worthwhile! Contrast and colour rendition is excellent.
On the down side, it is very difficult to get meaningful bokeh, but anyone who expects that out of a sub-6mm lens is dreaming. It is quite expensive, and you still need to shell out for a hood, which isn't even made by Pentax.
All up, it looks great, works brilliantly and has some rather fancy optics in such a tiny lens. It will not replace the 02 as a general purpose lens, but when I am only packing the Q7, and there's a landscape to be had, this will be the tool.
| | | | Loyal Site Supporter Registered: September, 2009 Location: Phoenix, AZ Posts: 7,001 | Lens Review Date: November 8, 2014 | I can recommend this lens: Yes |
Price: $450.00
| Rating: 10 |
Pros: | Excellent quality wide angle zoom | Cons: | Expensive | Sharpness: 9
Aberrations: 9
Bokeh: 8
Handling: 9
Value: 8
| | When this lens was announced I was very skeptical. How could anyone justify spending that much on a Q lens? Earlier this summer I had some money burning a hole in my PayPal account and a good deal on a new 08 appeared on Ebay. I bought the lens and almost immediately had severe buyers regret. I thought I had been an idiot to spend that much on a Q lens when I already had plenty of glass on my K3. Once the lens arrived all my doubts vanished. This is an outstanding addition to the Q line. Someone mentioned that they rate it with the 01 and rarely use the 01 now that the 08 is here. I understand that comment completely. I now use it as much or more than I use my 06 which has been my main Q lens for the past couple of years. I should point out that I am used to good lenses. I have the DA10-17; DA*16-50; Sigma 8-16; DA 15 and several of other DA* lenses and the Fa 31. Of course Q equipment does not match those lenses on a K3 or K5IIs but the 08 comes very close in many circumstances. If you do not understand the Q you may disagree but I think anyone who understands and enjoys the Q will find the 08 a wonderful addition to their camera bag - always assuming they can afford the purchase.By the way, I am aware that my over all rating is higher than the total of the individual scores. That is because with this lens it's value exceeds the sum of its parts. I have attached some sample pictures. | | | | Junior Member Registered: February, 2014 Location: Nissedal (Goblin Valley) Posts: 38 | Lens Review Date: August 9, 2014 | I can recommend this lens: Yes |
Price: $600.00
| Rating: 10 |
Pros: | Very light and small | Cons: | None | Sharpness: 9
Aberrations: 10
Bokeh: 10
Handling: 10
Value: 10
| | Fantastic little lens. Handles a ND filter with no vignetting. Very flare resistant. Best f.stop is f.4.5 for center sharpness. Extreme corners are a little soft compared to my Leica R 21mm.
