Irix 11mm F4 Firefly & Blackstone
What's in the Box
The Irix 11mm F4 comes with the following components and accessories inside its box:
- The lens itself
- Front Lens Cap (pinch-type, plastic)
- Two rear lens caps
- Lens hood
- Case or pouch depending on the version
- Serial number card / warranty information / manual
The Firefly version comes with a cloth pouch with a padded bottom and drawstrings. The more expensive Blackstone version comes with a semi-rigid, fully padded case opening like a clamshell. In both cases, the hood must be reversed before insertion.
Box contents (click to enlarge)
The lens ships inside an elegant metal case which is itself enclosed in a cardboard box. The color of these containers varies with the lens version.
Warranty
The standard warranty is good for two years.
