Pentax K-1 Review
Flash Modes
The K-1 has no built-in flash, but is furnished with a hot shoe with the contacts required to operate a Pentax flash in its various ways of operation. There is one exception: the original TTL flash protocol is not supported as we have become used to. The *ist D series are the only DSLRs with TTL support. TTL has been succeeded by P-TTL (programmed TTL).
It is nice to see that the K-1 has retained an old-school PC X-sync contact to which non-dedicated flashes can be connected. No camera controlled flash automation is available when using this contact.
The top flash sync speed is 1/200s. The speed can be adjusted with custom function 7. The following values are available:
  • EV steps set to 1/2 EV: 1/200s, 1/180s, 1/125s, and 1/90s
  • EV steps set to 1/3 EV: 1/200s, 1/160s, 1/125s, and 1/100s
There have been reports that certain third party flashes do not work with the K-1 with P-TTL automation whereas they work just fine with the previous models like the K-3 etc. We wonder if the problem could be resolved by lowering the flash sync speed to that of the K-3, 1/180s, though we did not test this hypothesis.
The flash modes that can be set on the camera are as follows:
Flash Mode Explanation
Auto: When the scene calls for it the flash will fire
    Auto with red-eye reduction: Same as above, but a pre-flash fires to make the iris of the subject close down thus reducing the red reflection from the subject's retina
Always on: The flash will fire independently of the ambient light
Always on with red-eye reduction: Same as above, but with red-eye reduction pre-flash
Slow speed sync: The flash will fire and the shutter speed will be set as slow as required to render the background
Slow speed sync with red-eye reduction: As above, but with red-eye reduction pre-flash
These modes must be combined with the modes on the flash gun itself to enable advanced features like rear curtain sync, high speed sync and multi-flash.
The flash modes which are available depend on the exposure mode. We ran through the combinations with a Pentax AF360FGZ II flash gun and noted the restrictions which the camera imposes. None of the exposure modes supports all flash modes:
Exposure Mode
Auto P, Sv, Av Tv, TAv, M, B, X
1 2 3
1 2 3
Notes pertaining to the table above:
  1. The shutter speed cannot exceed the sync speed when the flash is on. HSS (High speed Sync) is not available
  2. The camera will not let the shutter speed drop below a safe hand-holdable speed (disregarding the benefits of shake reduction). This makes the subject stand out if the background is too dark for a correct exposure with that "safe" shutter speed. Use slow speed sync to get the background correctly exposed. In slow speed sync the shutter speed will be set as slow as needed for a correct exposure of the background
  3. If a shutter speed faster than the sync speed has been set, the shutter speed will automatically be reduced to the sync speed when the flash and camera meter is on unless the flash is set to HSS (High Speed Sync). In this case flash can be combined with shutter speeds up to 1/8000s
The difference between "always on" and "slow speed sync" is illustrated by this example (click either thumbnail to enlarge):
Av exposure mode, flash mode always on Av exposure mode, flash mode slow sync
The presentation above relates to P-TTL capable flash guns from Pentax or fully compatible third party flash guns (i.e. Metz or Sigma units). If one uses the PC X-sync contact or an incompatible flash in the hot shoe the only relevant mode is the always on mode and the flash will fire unless the shutter speed exceeds the sync speed. There will be no pre-flashes emitted.
P-TTL
What is P-TTL anyway? This is a method whereby the exposure meter in the camera sets the flash exposure and one or more of shutter speed, aperture, and sensitivity. Which exposure parameters it set depends on the exposure mode selected (Auto, P, Tv, etc). The exposure meter bases its calculations on a pre-flash that is emitted just prior to the main flash. P-TTL flash automation is not available with M and K series lenses, since the camera can neither control the aperture nor determine which aperture value is set on the lens. Users of screw mount lenses must also forego P-TTL automation.
We noticed no unduly delay between pre-flash and main flash. The main flash basically fires instantly. Autofocusing takes place prior to the pre-flash.
By design there is a delay between the red-eye reduction flash and the P-TTL pre-flash. That is to allow the subject's eyes to adjust to the bright flash light before the main flash fires.
Wireless Flash
Wireless flash is available when using two or more wireless capable flash guns. Examples of such flash guns are the Pentax AF360FGZ, AF360FGZ II, AF540FGZ, and AF540FGZ II.
One of the flash guns must be mounted on the camera and it acts as a controller for the other flash gun(s). The flash guns communicate optically by signals encoded into a pre-flash.
Third party radio controlled triggers are available. A favorite among Pentax users are the Cactus V5 and V6 radio trigger systems. These triggers do not support P-TTL, so the light output of the flash guns must be set manually unless the flash guns have built-in light sensors as was the norm in the good old days. For further information read our review of the Cactus V6 triggers.
A wireless P-TTL capable strobe system is available for Pentax from Priolight. These strobes support high speed sync and are powerful enough to be used outdoors to freeze fast movement, for example. Read all about it in this article.
Pentax Flash Guide
Going beyond using just a single flash gun or two can be somewhat overwhelming. It doesn't get any easier due to the fact that the lens series also affect the matter. What to chose and how to work it? Creating a flash set-up for a studio can be a daunting task. Forum member Nigel McGregor has developed a comprehensive flash guide which you'll find here.
Verdict
Since the K-1 has no built-in flash, the flash modes that can be set on the camera for an external flash are limited to the basics (and hence uncomplicated, which is a good thing). To achieve advanced flash operation one must set the desired mode of operation on the flash unit itself (high speed sync, rear curtain sync, etc).  Of course, we're happy to see that the maximum sync speed has also been increased to 1/200s.
In connection with a recent P-TTL capable flash the various features are relatively easy to get to work.
To achieve wireless flash control at least two flash units are required: the one mounted in the hot shoe will act as a wireless controller, so the cost of an extra flash unit may be waiting down the road as a result of the lack of a built-in flash.
We would have preferred a built-in flash for convenience and also to save the cost of that extra flash, but compromises must be made and we instead got built-in GPS and Wi-Fi in a fairly compact body.
facebook.com/PentaxForums PentaxForums @PentaxForums News | Reviews | Forum
Support Pentax Forums Donate to Pentax Forums Support Pentax Forums
